Tool Modifications to my bead roller and shrinker/stretcher.
Tool
Specifications​
Motor1/6 HP 1.65 Amp
Gear Reduction75:1
Toggle Switch3 Position
Infinite Speed Adjustment0 – 20 RPM (11.8FPM)
Speed Control KnobInfinitely Variable
Foot SwitchOn/Off
Length20.5"
Width8.08"
Height9.06"
Weight18.5 lbs.
Specifications​
Gear Reduction75:1
Foot SwitchOn/Off
Length20.5"
Width8.08"
Height9.06"
Weight18.5 lbs.
So working backwards. 755W/HP divided by 6 is 125W divided by 1.65A is about 75V. Odd value. You'd think it would be a 24V motor.
Interesting stuff. What were you building your own controller for? And why did you end buying a solution?
I've got a treadmill motor on hand but I don't know that the controller board can be operated without the treadmill dash panel.
Probably a variable speed drive for my Gingery Lathe or else for the variable speed fan on my foundry furnace. The photos are dated 2003. The encoder was only for speed feedback, not positioning.
I then bought one of the treadmill motor controllers that runs off AC. It works but not at really low speeds. You can start it up at a higher speed and then turn the control to reduce it to slower but not a lot of torque there then.
I just checked and the device I used back then is now discontinued. So probably not even worth spending time on it.
You can buy surplus drives like this:
but they require tachometer feedback.
With LinuxCNC a brushless drive like that can be close loop controlled with LinuxCNC.
Don't know how I missed that. Makes sense then. 1500 RPM motor. I think the treadmills are rated at 6000 RPM.
Yes I think the tread motor I have now is way overkill. It's a 1500 watt, 4900 rpm. I have seen a small 400 watt treadmill motor that I think would have been ok.
