We will be meeting at modern tool January 12 2019 starting at 10 am. This will be an opportunity for you to wander there 30 000 square foot showroom and view there manual machines under power. Daljit form modern tool will be on hand to answer questions. They have a stock of new 14x40" lathes that we will be testing as seen in the links below. Also on site they have new mill drills and knee mills which will be under power and set up for demos.
http://www.moderntool.com/products/modern-model-935vs-1-milling-machine/
http://www.moderntool.com/products/modern-zx-45-drilling-milling-machine/
http://www.moderntool.com/products/modern-14-swing-40-between-centers-gh-1440-zx-heavy-duty-lathe/
One of the door prized provided by modern tool is a new Mitutoyo HD12-Ax height gauge
The second door prize is an R8 collet holder with fifteen type 25 collets
If you have further questions you can contact Daljit directly at 403 850-1365 the address is 11488 70 St SE, Calgary, AB the event goes from 10am untill noon on sat, january 12 2019
