Mistake
Other option is pewter, most pewter stuff you can find at thrift stores will be low or no lead, so safe and very easy to melt and cast. I melt it on a single-burner electric hot plate.
Ok, I get it now. He needs heavier mallet/hammer....
Yes, but no. Doesn't really need to be heavier. My plastic mallet works better than my brass one. It's all in the quality of the "thump"..... LOL!
I have got to try a plastic hammer or a dead blow hammer. My MT2 spindle is a real bugger to remove any MT2 arbor I stick in there. Everytime I hit the draw bar with a hammer I worry I will damage my spindle bearing.
There is probably a recommended torque rating out there but I try not to over tighten. It can suck the collet or arbor in tighter than it really needs to be, which just makes it difficult to remove. Bang-Bang removal is probably not great for the threads or the bearings. So tight enough so tool wont spin or loosen & just a teensy bit more. The way I stumbled onto this was occasional hand tightening & forgot to wrench obviously not paying attention. But I'm sure if it was heavier cutting I may not have gotten off as easy. My spindle is R8 so might be a bit different to MT. I use a Milwaukee cordless driver & socket on my drawbar, more as a reach convenience, but another plus is you can set the clutch torque & be somewhat consistent.
