Brian H
I have a Princess Auto mini mill that has a 350w DC motor and would like to upgrade it to a 500w(possibly even brushless). Has anyone done this? My google skills obviously suck cause I can't seem to make heads or tails of a compatible (read swap out easily) motor replacement. I feel a bit intimidated to just buy something and hope I can make it work.
I have upgraded to a gas shock on the Z axis and installed a reverse switch so far. I watched the Frank Hoose (mini-lathe.com) videos on adjusting gibs etc. and have it working very smoothly. However, when I try and drill a hole bigger than 1/4" in anything the cutout/safety switch cuts the motor out. I assume this is to protect the delicate plastic gears inside.
I haven't had any issues with milling or fly-cutting tho
Any suggestions?
Any suggestions?
