VicHobbyGuy
If you want a 7x lathe with a bit of support from the vendor (and pickup in the GTA and other cities) BusyBee has a Sieg 7x for $1k (on sale till Aug 14?).
I am not comfortable with neither Vevor or asc365, both selling pretty much just everything=whatever, almost like amazon
Not many other choices, only what I can do is sit back and fish.
For example I need to extend one internal M27x2.0 thread also to move couple M14x1.25 external threads.
These for sure limiting the 7" machines spindle bore, also an inch leadscrew is questionable.
Good luck with your search!Smallest possible machine, table top size, tight and precise, metric leadscrew, at least 25mm spindle bore size. I may use it several hours per month or maybe not. Needless to say spending more then a $1000 doesn't make a business case.
We'd like to help but I don't think there is a machine out there that meets your stated requirements. Most small, table-top machines are not considered "precise". But what does "precise" mean to you? The ability to regularly produce parts that go together with a press fit? Ease of creating bearing journals? Or parts that are within 2-4 thous (0.05 - 0.01 mm) tolerance? The latter is pretty easy for any machine in decent tune.Smallest possible machine, table top size, tight and precise, metric leadscrew, at least 25mm spindle bore size. I may use it several hours per month or maybe not. Needless to say spending more then a $1000 doesn't make a business case.
Thanks all for a great input.
