The wear on the hss looks to me like you are to low on the center line, my tool post is just like yours and I require at least 1 banding shim to get my hss to centre line. Use the pointy center on the tail stock to judge your height. Different cutters do make a difference here but typically you do not want above or below center. with the compound a little on the loose side leading to deflection you will never get it 100% right but that's the trade off from new expensive and new cheap. "The dial in"Thanks everyone,
Peter the tool was used for just the brass and the steel, it was brand new when I started. It was very slightly off center and orientated 90 degrees to the work and used right to left into the work piece. I spent a few minutes on the brass and less than a minute in the steel. It dulled immediately and the vibrations set up in the machine was very bad. It chipped when I was machining the steel, no filings were coming off just a fine dust and small chips and the tip burned up right away. Crap tool or more likely my technique orientation etc.? Making a sled out of tube steel so I can clamp to my welding table for use and see if that makes it solid and level as a start. Where is a good place to buy tools?
John thanks for the video links and I will learn how to grind these tools effectively.
Thanks Steve I now have a chart for speeds based on materials, I was just spinning fast for everything!
"Just plunk it on" sounds like you may want to double check that your set screw is not losing height (smack the pointy end of a nail on a table with your hand and watch as it gets smushed) or bending if .002" is a matter of importance.That's true Dabbler. But if you are changing tools while a part is already chucked & needs to stay put, like for subsequent machining operation, you wont have the opportunity to turn a new center or insert one in the chuck. Sometimes you can swivel the toolpost around to point to a center in the tailstock. But sometime that's not practical or possible either. The 'steel rule' method actually works not too bad. I guess that's why the height locking tool holders were invented, huh? 🙂 That way all the tools are pre-cenetered & just plunk them on the toolpost. Sooner or later everyone runs into this though - chip a tool or break an insert mid-operation sharpening required changes height... Good discussion.
