I tend to break the carbide cutters. These are cobalt so a bit harder than regular HSS. I'll report on them after I try them out. These cost roughly $4.30 each and they are sharper than any of the other HSS I've got.One word......
C A R B I D E
To be fair HSS tooling is how I started, but since I've switch to carbide there is just no going back.
Less deflection
Better wear
Longer life
More aggressive cuts
Better heat tolerance
I'll be interesting in hearing how it works out, particularly at a disposable price range.I tend to break the carbide cutters. These are cobalt so a bit harder than regular HSS. I'll report on them after I try them out. These cost roughly $4.30 each and they are sharper than any of the other HSS I've got.
It might also be the horrible backlash in my House of Tools mill that contributes. Although I do have backlash compensation built in with a larger cutter in steel I watched the cutter grab the material and pull the table. One solution is to really tighten up the ways or... a no brainer... get after project #42 and install ball screws.I'll be interesting in hearing how it works out, particularly at a disposable price range.
I found cutter speed on carbide is important (generally higher than on is used to, which why you break them if run to slow as chip load is reduced, remember no flex/give in comparison) but this creates heat acceptable for carbide (to a point) so cooling for material and cutter becomes important.
Try conventional milling instead of climb milling, then you don't have to worry about backlash (in this regard).It might also be the horrible backlash in my House of Tools mill that contributes. Although I do have backlash compensation built in with a larger cutter in steel I watched the cutter grab the material and pull the table. One solution is to really tighten up the ways or... a no brainer... get after project #42 and install ball screws.
I have backlash in mine too, sigh, ball screw project and tuning quill feed system (pain).It might also be the horrible backlash in my House of Tools mill that contributes. Although I do have backlash compensation built in with a larger cutter in steel I watched the cutter grab the material and pull the table. One solution is to really tighten up the ways or... a no brainer... get after project #42 and install ball screws.
Mostly scrap aluminum castings, some aluminum extrusion material (also scrap pieces). Less steel parts but I do steel too. Often I'll try a 3D print first for trying things out. If they break I make them from something else. You can see from the lines on the steel part my depth of cut and the positional issues.John,
What type of material will you be using the new endmills on ? They should stand up fairly well if your not too aggressive with them.
Your speed, feed and stepover in which material you want to machine will determine how long they stay sharp. Coolant vs air as well.
Its been many years since I have used those types of endmills but, that was all we had to use before carbide came along.
Things took longer to complete but we still got things done,,, eventually.
I hope they work out for your project.
