I'll be the first to ask why?Hi All,
Has anyone added actuated gib locks to a g0704/cx601 type mill? I am thinking of using quarter turn rotary actuators or stepper motors. Has anyone come across a build log where someone has already done something like that? Or maybe a premade kit?
To lock the gibs when I push a buttonI'll be the first to ask why?
Yeah I got that. But is it so inconvenient to do it manually? Do you do it really often? Is the machine CNC controlled so do you want to lock all at the same time or only the stationary axis?To lock the gibs when I push a button
Haha, ok then, I will explain more than the obvious. It is a little inconvenient to reach the y gibbs, but it’s not that, really. I often forget to engage or disengage whichever ones I need to, so having a panel with a button to push and a status light would be helpful. Maybe I will use one of those fighter jet style covered switches for extra cool factor and to appease my inner child.Yeah I got that. But is it so inconvenient to do it manually? Do you do it really often? Is the machine CNC controlled so do you want to lock all at the same time or only the stationary axis?
Inquiring minds need to know.![]()
Hi All,
Yeah something with programable voice module just think of the possible messages like.You prolly don't need yet another fellow recommending against this project. But that would be me. There are lots of way more useful projects than this one that is a giant rabbit hole. It's very complicated and fraught with opportunities to go wrong.
Personally, I'd work on ways to instill better habits and look for a better project to do. Since you are willing to do some electrical / electronics, why not a simple Arduino reminder that you have to acknowledge regularly. If that doesn't burn in the habit, nothing will. And, you get to play with an Arduino!
Haha, yeah it sounds like we may have a thing or two in common. Is this where I confess I am an engineer too? Is this a safe space?I should follow the KISS rule more frequently - but I confess i often build something that takes hours and only occasionally saves a few seconds. So i get why you’re thinking about auto gibb locks. Makes way more sense than many of my projects.
My Z axis gibb locks are on the right side of the mill (RF45 clone) but the raise/lower hand wheel is on the left side. What st##pd engineer design that! (see note below).
My Y axis gibb locking handle not only conflicted with the table (if the Y gibb lock handle is vertical up then it conflicts with the table during X travel) but it is also hard to reach or even see. In photos below - this time I had a simple/quick solution - I attached a socket extension. So maybe @GKShop consider a project to improve gibb lock access and visibility.
(Note: I am an engineer and I don’t mind pocking fun at some fellow engineers that don’t have a practical bone in their body)
I often do things like this just because I can and it’s a challenge. I even occasionally learn something, but if I’m careful, I can avoid that.
I’ve enjoyed the conversation, thanks to all for your input, so far. If you would like to make any more suggestions, please feel free. There may be some other fool who wants to try this one day.
Well the leafs make sense since it's all about drugs right? The leafs from the marijuana plant? And we don't talk about drugs.Safe? From being made to feel dumb? The only thing on this site that is verboten is politics, and maybe being a Leafs fan.
Those pictures have given me some ideas on how to possibly fix my X slide on my mill lock. There are two hex head bolts for my gib locks but since I put on DRO scales in the front there only 1 of the hex head bolts is accessible. Thanks for the ideas.I've seen a few mechanical variations to the '1-handle 2-screw' theme on mini mills. Some Google examples below. I never found it enough of an issue on my RF-45 to make anything special. Anything knob like was too close to table underside due to the diameter if it had any mechanical advantage. The stock handles were the typical sprung type that could be adjusted by pulling out & reset to a different angle on the spline. I just found a position where they tightened about 6:00 (down). To loosen was just 1 full turn, but again residing down. And both handles were adjusted the same. I have found that some handles have less splines for whatever reason. There is no a lot of force on these. In fact if you gronk them you will see a series of bite marks down the gib strip. On my lathe I modified the screw to have a little brass foot angled at same 60-deg gib stril & a bearing ball. Thatway its more like direct oblique force vs turning o the gib strip.
