Tool Maybe Beyond My Skill Set And Needs
Tool
Apparently it is just loosing molecules on it's own. It is a slow process but the "powers that be" are getting worried about it.
I suppose if it gets to bad it would invalidate the metric system, then we might have to adopt something else. Better dust off the old yardstick. he, he, he.😎
So it looks like the meter isn't a meter anymore
I believe that the meter is a constant precise length that is (by definition) directly related to the speed of light in a vacuum. Also - speed is a distance and time relationship. The time portion of that relationship is defined using cesium-133 (atomic physics defines a second).
maybe one these would do... 🙄 😛
Well, the current definition of a meter is only the latest definition. It has had various definitions, starting out attempting to relate it to partial meridian arc length of the planet we live on. Noble intentions, 7 years of toil & all that entailed. The platinum bar stuff was mostly about selecting a material with minimal deviation given the technology of that time to reflect that length basis. Now with the benefit of modern satellite technology we know they were within 0.197 mm/m. In the end it doesnt matter, it was a glorified gauge block by which everyone else 'calibrated their sticks'. And that is actually no differnt than other so-called standards.
The English foot came from human anatomy (super reliable!). It got more defined with yard (3x foots). But really followed a similar path, just less effort to tie it to anything meaningful. A chunk of material (brass > bronze > bailey's metal?>...) finished to some length, given a label & stored in THEIR vault. Another glorified gage block by which others shall follow, at least in areas of their domain which was substantial when they cooked up their definition. In 1893 (Mendenhall Order) the Americans said, well we like the word 'yard', but we dont trust the English bar, so we are going to base our yard on the French meter just by using a conversion factor. It took Canada until 1951 to come to the same conclusion, severing the London yard, making our yard = 0.9144 metres (exactly). At this time our yard was different to USA yard but only because of different conversion factor to the same metre. Then in 1959 we (including the British) all agreed on common inch/yard/related lengths by agreeing on a common conversion factor to a meter. Hopefuly in this convoluted history, the Standard vs Metric argument is really rather silly since (USA/Canada/Britain) Standard has been BASED on metric for a very long time, at least for length.
As physics & technologies evolved, along come a better recipies to define length without upsetting the metre applecart too significantly. 1960: Krypton-86 wavelength standard, 1m =1,650,763.73 wavelengths, now accurate within a fraction of a micron. Then 1983 Speed of Light Shift: chose the exact integer 299,792,458 metres per second because it matched the existing Krypton-86 metre standard to within experimental error. All this means is anyone (with the right equipment) can replicate the standard. It doesnt effect a carpenter using a tape measure or machinist using highest grade gauge blocks available. That was never the point, our low level requirements & buy-in are inconsequential. But as you work up or down the distances from micro to macro used in modern day physics & industry, you run into the same old 'what constitutes the standard stick' syndrome.
And handy, everybody has two. Just whip out the old size twelve and measure away.
Unless you are the poor sap that has to make Part-A fit Part-B & realize its just circular silliness Q) how long is a size-12? A) 12 inches. Q) Whats an inch? A) One 12th of a foot Q) how long is a foot? A) well 3 of the King's feet (left one I think) placed end to equal The Royal Yard, but first you must sail to London to measure the offocial brass one, hopefully not a cold rainy day when it will actually be just a tad shorter.....
Remember what they said about John Wilkinson boring machine. "It bored a hole with only a shillings distance out of round". Using a size 12 foot would probably been close enough.
Time to hoard imperial tapes, yardsticks, F thermometers, pound scales, etc to preserve the old knowledge 😉
This was mostly a joke until I dropped a tape last week and broke it. So far striking out replacing it in Canada with imperial only, like you used to be able to get. The little 12' ones were good for tool boxes and glove boxes. I'm going to grab a few from Wisconsin or Michigan I guess. I saw Stanley makes a 16' FatMax but didn't grab one last week
I'm a bit surprised by this. At work we have a bunch of them, pretty much all are new within the last 2 years.
I'd like a dedicated metric tape to match my inch one and that is hard to find. IMO the combo ones are irritating for everyone, all the time.
I prefer the dedicated ones too. But I might be OK with one that has imperial down BOTH sides and metric down the middle or vice versa. What I don't want is metric on one side and imperial down the other. Invariably, they are backward to what I need.
Lately, I've been using a small laser tape measure.
These are awesome! Especially the green laser ones. I just wish they had a better rear index for zero. It would dirt simple to do. Why they have not done it is beyond me.
