Well, the current definition of a meter is only the latest definition. It has had various definitions, starting out attempting to relate it to partial meridian arc length of the planet we live on. Noble intentions, 7 years of toil & all that entailed. The platinum bar stuff was mostly about selecting a material with minimal deviation given the technology of that time to reflect that length basis. Now with the benefit of modern satellite technology we know they were within 0.197 mm/m. In the end it doesnt matter, it was a glorified gauge block by which everyone else 'calibrated their sticks'. And that is actually no differnt than other so-called standards.
The English foot came from human anatomy (super reliable!). It got more defined with yard (3x foots). But really followed a similar path, just less effort to tie it to anything meaningful. A chunk of material (brass > bronze > bailey's metal?>...) finished to some length, given a label & stored in THEIR vault. Another glorified gage block by which others shall follow, at least in areas of their domain which was substantial when they cooked up their definition. In 1893 (Mendenhall Order) the Americans said, well we like the word 'yard', but we dont trust the English bar, so we are going to base our yard on the French meter just by using a conversion factor. It took Canada until 1951 to come to the same conclusion, severing the London yard, making our yard = 0.9144 metres (exactly). At this time our yard was different to USA yard but only because of different conversion factor to the same metre. Then in 1959 we (including the British) all agreed on common inch/yard/related lengths by agreeing on a common conversion factor to a meter. Hopefuly in this convoluted history, the Standard vs Metric argument is really rather silly since (USA/Canada/Britain) Standard has been BASED on metric for a very long time, at least for length.
As physics & technologies evolved, along come a better recipies to define length without upsetting the metre applecart too significantly. 1960: Krypton-86 wavelength standard, 1m =1,650,763.73 wavelengths, now accurate within a fraction of a micron. Then 1983 Speed of Light Shift: chose the exact integer 299,792,458 metres per second because it matched the existing Krypton-86 metre standard to within experimental error. All this means is anyone (with the right equipment) can replicate the standard. It doesnt effect a carpenter using a tape measure or machinist using highest grade gauge blocks available. That was never the point, our low level requirements & buy-in are inconsequential. But as you work up or down the distances from micro to macro used in modern day physics & industry, you run into the same old 'what constitutes the standard stick' syndrome.
