Making a Thingamajiggy
Still working on it.
I needed to make a mechanism to provide andjustable tilt for the Thingamajiggy.
I used a 6" Rotary Table for the arc cut-out. And I'll tell you 6" is too small. Not enough surface area to bolt stuff onto. And to make matters worse is that the t-slots are never in the right spot. I've been contemplating bolting on a 10" plate with plenty of threaded holes. But maybe I should try to find a good 10" RT.
