Maching a Ford Super Duty Wheel Hub to Make a Wheel Adapter for a VW
ruzter
New Member
I have a Volksrod project.
For my rear wheels, I need a wheel adapter to go from VW beetle 4x130mm to 8 x 170mm which is a ford super duty F250. needless to say they don't make this and I would be too cheap to buy them anyways.
Here is a mockup I CNC'ed from MDF
upload_2016-6-10_18-41-37.jpeg upload_2016-6-10_17-13-11.jpeg upload_2016-6-10_17-15-49.jpeg
I got the front hubs today ($15 each) and plan to machine them as my first lathe project that I do by myself on my lathe.
Basically I will machine off everything that isn't the flat disk and drill holes for the 4 VW lugs. I will leave a lip on the front for the rim to register on.
For my front rims, they are aluminum with a 4x100 pattern so I will just mill/drill and alternate pattern for 4x130 (pic at the end)
upload_2016-6-10_17-15-49.jpeg upload_2016-6-10_17-16-4.jpeg View attachment 808 upload_2016-6-10_17-18-30.jpeg upload_2016-6-10_17-20-13.jpeg
Alexander
Dude that is awsome. Why do you want to use the big truck wheels? Looks cool and road worthy.
ruzter
New Member
Thanks!
I wont be using those tires. They are 16 inch rims so I can get almost any tire I want and it is a wide rim so I can use a wide tire. Plus I got them for $30 a piece. I have some 265 wide tires to try, I will have to see if they are too big. I picked a 8 lug rim because it is easy to space 4 lugs between 8. going 4 to 5 is a pain and requires a 2 piece adapter or one with a funky offset lug.
The rim I got are also reversible and they look quite funky mounted reverse.
thanks for the comment
ruzter
New Member
Aluminum wheels have new lug holes! just need to chamfer them. My first time really milling. Gotta love a DRO. I may put dummy lugs in to fill the unused holes. Anyone know why the pics come in rotated and how to fix them?
Jyman
Hey ruzter,
I would love to know more about your project, I love old cars and trucks. Do you plan on taking it out to any shows when it's finished. By the way I'm in The park also
ruzter
New Member
Hey ruzter,
Well originally I was hoping to have it done for the car show at the church on Wye road and clover bar in late August but you know how that is. I have three weeks off in early August when I'm hoping to get lots done. Again you know how that goes. I'll try to take some pictures and post them in separate thread
JohnW
The rotation problem is with the capabilities of the image editing and display software you are using - whatever it is. It may even be your iPhone not setting the orientation data properly when the image was taken.
Many digital cameras (just about everything in the last 5-7 years) have an acceleration sensor so they can detect when way the camera was oriented when a picture is taken. In most cases the image data stored in the file will be saved as it was taken off of the sensor (after correcting for the upside-down and backwards image created by the lens). If you rotate the camera by 90 degrees, the pixel data stored in the JPG usually remains the same, but there is additional image meta data called EXIF tags that are stored inside the file. That usually includes data such as the lens opening, focal length and shutter speed used on the image. Where there is an acceleration (gravity) sensor, it will usually include the "orientation" data tag, which indicates where the "top" and "left" side of the image is.
The orientation data can be wrong when the camera is pointed nearly straight up or down when there is no real indication of what the "top" of the image should be in reference to gravity.
The issue is whether the image editing and viewing software you use (including the rendering engine in the browser, and the HTML generated by the forum software) properly handles the EXIF orientation tag.
For instance, the image with the tire on the rim includes the following EXIF metadata:
Camera - Apple iPhone 5s back camera
Taken - 2016-06-11 @ 4:06:35pm
1/15 sec, f2.2, iso 320, 4.2mm focal length, no flash in automode.
Orientation: 1
The orientation tag indicates how the image should be viewed. the software displaying the image may rotate it as it thinks it should, or it may not rotate it at all. For instance:
  • When I see the image using IE11, or Chrome V51, I see that image with the top at the left.
  • When I download it and see the thumbnail in Windows Explorer under Win7, I see it with the top at the left as well.
  • Opening it in Photoshop V5.1, it is rotated correctly.
  • Windows Paint and Windows Photo viewer do not rotate it correctly.
  • Breeze Browser rotates it correctly.
The handling of orientation meta data is supposed to be standardized, but it is not quite right in the real world.
