Sorry, I miss wrote. It was Dabbler not Sasquatch who saw the Prusa XL on his swing through this area. Opps
Pierre
David,Very pleased with my Anycubic Kobra S1 with the Ace Pro. Not had a failed print yet and I have about 250 hours on it.
I have not done any multicolour prints but the ease of changing colours and the built in dryer is worth the cost.
I'm using the Anycubic slicer as it allows LAN mode (vs. cloud) connection to the printer. It's a fork of Orca slicer.David,
Kobra S1 arrived and I made some time to power it up. Seems to print well ( just PLA so far).
1) are you able to send files from your PC to the printer via WiFi?
2) What version of slicer are you using?
What version of Anycubic slicer?I'm using the Anycubic slicer as it allows LAN mode (vs. cloud) connection to the printer. It's a fork of Orca slicer.
Sorry I was mistaken, the Anycubic slicer is a fork of Prusa Slicer not Orca Slicer.What version of Anycubic slicer?
(BTW looks to be a derivative of Prusa slicer to my untrained eye)
When I configure Anycubic slicer, I don't see a selection for Kobra S1, only Kobra3, it seems to work, but video I watched shows selection for S1, it might be because laptop I'm running slicer on only has Win7?
Or I'm using wrong version of Anycubic slicer?
What version of firmware are you using on the actual printer?
I do like some of the features:
+ ease of filament loading
+ multiple filaments and dryer
+ one of my Prusa's had the flexible metal hot table plate, but the old Prusa did not
+ better display
+ carbon filter
+ quieter because of enclosure
+ quality seems quite good and good unpacking instructions
+ looks cool!
- I will assume Wifi connect, but I don't have that working yet
- have yet to do anything with the camera, have you?
I ordered a new hotend thermistor for my old Prusa ($10) looks like an easy fix so I will resurrect it when it arrives and then probably sell both Prusa I don't have the space for a a 3D printer farm;-)
Thanks for your suggestion lots of "+" so far.
David.Very pleased with my Anycubic Kobra S1 with the Ace Pro. Not had a failed print yet and I have about 250 hours on it.
Creality k1c firmware is open source. You should be able to update and change the options you want. Might have to go to klipper if you really want full control. I think there is an update you can print for the spool holders. Also make sure the enclosure is latched when printing. You can try these with the cardboard spools. It shortens the gap between the spring plates and the spool. https://www.printables.com/model/1103497-creality-k2-plus-cfs-fix-for-small-spools-retractiOk, a bit late for some negative comments on my K1C combo. Was advertised as being capable of 0.2 nozzles but a firmware update made that 0.25mm, which Anycubic doesn't have available (been a few weeks since I checked).
Not planning on using that size much but definitely want to try it out on some small stuff.
My AMS has jammed a time or two. It definitely retracts the filament more than needed and causes it to bunch up, as the cardboard spools are not rotating well. So plastic spools are needed, which is a pain. Need to buy your filament on a plastic spool or rewind yourself or one of the other methods of getting it on a plastic spool.
Firmware is closed. So I can't adjust the parameters for retraction on filament change to fix that myself.
The firmware seems to be programmed in a very linear way for preparation actions when a parallel approach would speed things up - i.e. nozzle temperature changes after probing, waits until homed to raise the temperature when it could be doing that while in motion. Lots more examples but I've been away from it for 3 weeks so I've forgotten about specifics.
On the whole it is much better than my last printer (would be about~7years old now) but still leaves room for improvement in interface (no built in help, no user manual) and no reason to keep the firmware closed, it's all derived from others anyways so no real IP to protect. I suppose it may help cut down on support tickets, but then again so would a user manual and built in help menu (in the slicer)
How about a AnyCubic Kobra S1 with AcePro for $800Cdn delivered ;-)What kind of machine can you get that will produce useable, finished parts, unattended, for USD$1600?
