Looking for benchtop milling machine
Hello all, new to this site, and looking for a benchtop milling machine. I’m in Alberta. What machines would you recommend for small projects? Thanks in advance!
Mike
ersatz engineer
There are at least 2 of these owned by members that are relegated to drill-press duty, because they own a bigger one (or 2). Perhaps one of these might free up one day soon!
https://www.busybeetools.com/products/milling-machine-digital-readout-r8-cx600.html
I have this. It's pretty good. Used gives you more bang for buck. A x,y scale DRO is a useful addition.
Similar: https://www.kmstools.com/king-industrial-3-4-milling-drilling-machine-with-digital-readout-149103
https://www.busybeetools.com/search?q=igaging
Some modest DRO's here listed.
Set aside money for tooling and material too. You will need end mills and holders, perhaps a face mill, drill chuck, drill bits, and a milling vise. A digital caliper (iGaging is a good start) and some tools for marking.
Tom O
I have one like Johns from Busy Bee that I put a 4 axis dro from DRO Pro’s so the quill reads when in use integrated with the z.
Pictures Tom? 4 axis? Did you instrument the column and the quill? Does the measurement combine somehow?
Ok thanks for the advice!
Tom O
It is built into the Dro you can use them separately or together. Installing on the quill wasn’t bad either I was able to pull the readout and use its original parts while fitting it I did make a new cover for it though, I’ll see if I can post a few pics later today.
Tom Kitta
Get a DRO from aliexpress. Cheap and accurate. Both me and others have used them for years now without any issues. Expect to pay around $200 or so for 3 axis dro kit (glass scales).
