KBC - USA,TPGB-21-51-EN-DC656 COATED INSERT,1-512C-003,KBC Tools & Machinery
KBC - USA,TPGB-21-51-EN-DC656 COATED INSERT,1-512C-003,KBC Tools & Machinerywww.kbctools.ca
It says there are ten in the package$21.92 for a single insert <$$ gasp $$>
I was going to guess Sandvik or Valenite or similar? I'm not sure if there is an exact cross reference where you can find something cheaper/equivalent. That's kind of their game, good quality but unique sizes.
At minimum I would check Ebay for exact size matches. Guessing you can get a surplus pack of 10 for similar $. These may not be exact matches but just as example.
Valenite TPG 2.521 VC2 TPGN 130304 Carbide Turning Inserts (Box of 9) | eBay
Find many great new & used options and get the best deals for Valenite TPG 2.521 VC2 TPGN 130304 Carbide Turning Inserts (Box of 9) at the best online prices at eBay! Free shipping for many products!www.ebay.com
Sandvik TCMT 3(2.5)0-UF 525 Carbide Insert 16 T3 02-UF (Pack of 10) | eBay
Find many great new & used options and get the best deals for Sandvik TCMT 3(2.5)0-UF 525 Carbide Insert 16 T3 02-UF (Pack of 10) at the best online prices at eBay! Free shipping for many products!www.ebay.com
I might be wrong , but none of those, are close enough. First has no mounting hole in the centre, second is two sides insert... not sure. not an expert here$21.92 for a single insert <$$ gasp $$>
I have this tool holder with insert for cast iron or non-ferrous metals. I am a bit struggling to find any insert for regular steel or aluminum. Wondering if those inserts are even exist for this tool holder or it is specialized for that insert only
Good catch, I should have scrolled down & read completely before jumping to conclusions.It says there are ten in the package
Like I mentioned these were not exact matches, just intended examples. I had 'big name' (example Sandvik) on the brain. Some of their sizes are unique to their toolholders. But if the subject toolholder/insert size is a more generic tool, finding good quality inserts is considerably easier. And cheaper.I might be wrong , but none of those, are close enough. First has no mounting hole in the centre, second is two sides insert... not sure. not an expert here
I'm with @Susquatch, grab a new holder and inserts
I also run the triagon inserts in a 5/8 holder, very tough insert, I have lh, rh turning as well as lh and rh boring bars for the same insert, so it is cost effective in the long run
Thanks Susquatch, folks. That was impulse buying. I can, probably return it, did not used it at all.If I had your problem, I would go a different way entirely.
If we are on inserts subject - wondering if there such thing: carbide insert that is sharp (not requiring too much force to cut) and tough at the same. Something like a cross between regular insert and sharp aluminum? I am watching lots of youtube on this and see that people are often using aluminum inserts for steel - i tried myself it is not holding up very well.
Also - Susquatch - why trigon is bad ?
I have 12" Hendey and 10" South Bend . I know that it has to be different sizes of the toolholders, but I hoped I can get away with same insert sizes. I am pure hobbyist - no production, no rush so smaller insert for bigger toolholder is very viable option.what size lather do you have ?
