Machine Looking for a manual and or opinions
Machine
millwrightgoose
Active Member
Just picked up this lathe for my home shop However I have a few questions Regarding lubricants, the lathe is a j1mt 360 based of a mazak lathe from my research. I’m in need of the oil weights for the carriage and headstock. I’m assuming something similar to 220 gear lube in the headstock? Anyone with any knowledge of these machines? I would also love to buy/ get a few pages out of a manual if anyone happens to have one.
If your open for an opinion I’ll give mine. This is by no means scientific or gospel. I have a manual to an older Voeste lathe and it calls for hydraulic 32. One of my other lathes calls for something similar. I can’t imagine a home shop working a lathe of this size to its limits. Try 32 and watch thre colour. And congratulations on the new toy. I have a chin hung ( similar to this one) and absolutely love it. Don’t get caught up in the Taiwan off shore isn’t as good as .......... crap. This will serve you just fine.
It’s a bit pricey, but here is a link to a manual for your lathe.
IIRC, the oil in the carriage on your lathe feeds the way lubrication system. In that case, the oil should be a good quality way lubrication oil NOT gear oil. I use Shell Tonna 68 for both my lathes (a Colchester Master 2500 and a CMT Ursus 250) that have integrated carriage/way lube systems.
For the headstock, hydraulic oils work well. ISO 36 works well in mine (both have clutches).
Great looking lathe in nice condition! +1 to all of @RobinHood comments.
Also think of it this way: You will use way oil over time. For the headstock you need around 2 gallons anyway. Buy a 5 gallon bucket of Tonna 68 (I also use this, it is great), and be done. Then you have left over for the apron and lubing the ways on this lathe and your mill...
The dirty secret is that almost any lube will work, except the 220wt gear lube you suggested. It is far too thick to do splash lubrication, which is what all the old Mazak lathes used.
Gears need lubricity and film strength. Hydraulic oils and way oils have very strong film strength, and the way lube has the advantage of staying with the gears between uses. Lubricity of current oils is superior to any lube available in the 70s.
If you want to use a separate lube for the headstock (in the case where it isn't used for lubing the ways), use Hydraulic Oil 68, as available from Princess auto. Only use the 32 if you have a very cold shop in winter. The 32 is too thin and your gears will always start dry after even a short interval (a few days).
A caution here: stay far away from sulfated HP oils. They will eat your bronze and brass away in a short time. Your headstock has a bunch of bronze or brass in it. High pressure lubricants are not to be used in spur gear boxes in any event.
Legend reply!
OR - iso 46 ( middle ground ) if your work has some and is willing to sponsor your oil adventures :D
Thanks everyone for the replies! This forum has a plethora of knowledge, boring old 68 hydraulic oil it is! Now to find a rotophase as I just cooked my vfd. @Dabbler appreciate the compliments! Took a few hours of degreasing to clean it up like that. Thankfully the ways seem to be excellent just a few small issues I would like to attend to.
If you do need to use EP oils in a gear box that has yellow metals, then find one whose ingredients use inactive sulphur instead of active sulphur and has an copper strip corrosion test (ASTM D130) no higher than 1A.
View attachment 42626Just picked up this lathe for my home shop However I have a few questions Regarding lubricants, the lathe is a j1mt 360 based of a mazak lathe from my research. I’m in need of the oil weights for the carriage and headstock. I’m assuming something similar to 220 gear lube in the headstock? Anyone with any knowledge of these machines? I would also love to buy/ get a few pages out of a manual if anyone happens to have one.
Hi there, I was amazed to see this picture of your Lathe.
I have a 1977 Mazak-Mate, which looks identical to what you have there!
I have only seen one other Lathe that is identical looking to my Mazak-Mate, and it is located in the Machine Shop at Highland Valley Copper (Canada's largest Copper Mine)
I'm curious if you got a set of gears for the primary gear drive for threading & travel? I only got the "A" set with mine!
Can't really contribute any knowledge here but Max Grant on YT has one of these (a touch bigger maybe) and he has several interesting videos repairing the machine.
Nice score.
My Colchester takes Tellus 27 in the headstock and 33 in the carriage or equivalent. You should be able to find an industrial lubricant supplier in your area. Definitely pop the top of the headstock and flush and clean and replace though, you never want to replace bearings and gears.
Nice score.
Inheritance machining on youtube has one identical to mine, I will have to check out max grant!
Manual on ebay.(The listing shows a few pages of the manual) $26.00US. from Jinan, China. (I think that is where they were made. )
I'm a retired millwright, our mill had guite a number of machines, each with it's own lube requirements . After I retired I picked up a used lathe and a Rong-Fu 45. These were the original square column gear head mill/drill. Both needed work, but I'm a millwright. I heard the gears in H. I thought in the future a gear change was in order. After the motor wiring got sorted out and the feed screws and nuts changed, I did the oil. It called for ISO 68 . I didn't need that much, but I did find some at tractor dealership,(orange and red, with some German green). They kept it for older tractors. Much to to my great surprise , that quieted down my noisy gears !
At work we used that grade oil for the big bearings on one of the stranders.
