Line Noise Suppression Capacitor?
I ran into that problem with a relay on a board for a dryer. My soldering iron wasn't up to the task so I took it to a TV repair shop and he did it for 20. I figured this was cheaper then me buggering up a $400 board. LOL
You have to be right that you were getting heat sinking on the board. Try the heated TIG rod thing.
Tin solder melts above 400F (but not much above - depending on brand, 420-440F I just used my iron at 750F and easily melted a blob on an ROHS board.
- probably adds confusion to the matter, however.
There is a special solder used to desolder that drops the solder temperature, I belive Sayal has some in stock otherwise Digikey, Mouser.ca or Amazon.
Desolder wicks and Desolder Vacs are the way to go.
I use only Leadfree, but it important to understand that not all lead free is equal. KOKI brand is the best hands down. Behaves like leaded if used correctly. Ideal temp range between 715-735C, I typically run 725C
I'm starting to run low on my Kester. Where do you get KOKI & what part number/composition?
Success!
I tried with a 0.070” HSS drill heated to red hot with a propane torch to melt the solder first thing this am. No joy.
Deckel GK12 pantograph to the rescue. I set the board up upside down on parallels to mill off the excess solder and the protruding component lead. This is a 9/64” three flute end mill, 8000 rpm.
If you look closely, you can see the center of the hole - it’s the copper of the component lead. (The circle is where I touched off and scored the coating of the board). Next I got a 70 thou carbide PCB drill and peck drilled it out. 20000 rpm for this op.
The holes drilled out.
Then it was just a matter of soldering in the new cap.
All done. Thread mill works like a charm, btw.
Thanks again to everyone that chimed in to help me out. Much appreciated!
Yes, I does help when you have access to precision high speed equipment.
Besides a little bit of manual engraving, this is the sort of stuff I have used the GK12 mostly. I only have the one 1/4” collet for it but I have made reducing sleeves for both 1/8” and 1/16” shank tooling. Comes in handy when you need to drill out a busted off HSS tap in a hole. The little carbide drills at high speed (and air cooling from the blowgun) make relatively short work of the tap. Saved my bacon a bunch of times…
I am missing the factory “overarm” which converts the machine from a pantograph to a “straight” milling machine (part in red box). This overarm can also be used to attach patterns to follow when milling. No pattern => rigid spindle.
I get around the lack of the overarm by clamping the “pattern side follower” into a vise. Since the relative moment arms are huge, the spindle is held very rigidly for operations like the one I used it for on this project. I would not use anything bigger than a 1/4 cutter for any milling operation as the spindle, and pantograph mechanism for that matter, are delicate and could be damaged by large side loads.
I am missing the factory “overarm” which converts the machine from a pantograph to a “straight” milling machine (part in red box). This overarm can also be used to attach patterns to follow when milling. No pattern => rigid spindle. I get around the lack of the overarm by clamping the “pattern side follower” into a vise. Since the relative moment arms are huge, the spindle is held very rigidly for operations like the one I used it for on this project. I would not use anything bigger than a 1/4 cutter for any milling operation as the spindle, and pantograph mechanism for that matter, are delicate and could be damaged by large side loads.
The mind reels at the possibilities! LOL
