I recently brought home a copper boiler from my dad with the intent of getting it done so the locomotive its for could be moved towards completion as the running gear is basically done and running on air. Its for a 3-1/2" gauge Maisie.
Well, after making up some plugs for the openings I gave it a preliminary pressure test with city water pressure - unknown pressure but maybe 70 psi max - I feel its actually less where I am. Thats against a static test that will be at 200psi+ when (if) the time comes to do a proper hydrostatic test.
Anyway, we had been chasing a bad leak around the foundation ring that would not even let it fill and it appears that is fixed (see flat plates added to back corners), but now the rest of the boiler resembles a lawn sprinkler more than a pressure vessel.
Looking closely at the (excessive) silver solder, it looks "cold" around the leaking stays. Theres even a leak in the middle top of the firebox where there aren't even any through holes - that one is a real mystery unless it was a through hole for rivetting on something inside the crown?
Just wondering out loud - has anyone recovered a boiler from this state or will I just be fixing one leak and making several new ones as we have already done? Options are give up and start over (just materials alone will be $$), pay ~$3500+ for a prebuilt one from the UK (silver soldered), and there are vendors who Tig weld boilers (special grade of copper and technique to prevent cracking - who knows how much $ for those).
