Lathe test bar
skippyelwell
I've purchased a 3ft piece of 3/4" tool steel/drill rod and am getting ready to make my own test bar to align the new lathe.
I've watched a couple of vids but I thought I would ask you guys before I start cutting if there is anything I should watch out for, tricks, tips?
Why cut ? Run an indicator instead.
The straightest rods I have found are hydraulic cylinder rods. They are also chromed and dead hard. Drill rod is nowhere near straight enough IMHO.
I scrounged some from a local equipment place that services farm machinery. Cutting to length was a job though.
We have had this debate on here before.
My short summary of those discussions are that running an indicator on a known good bar isn't good enough. It's too difficult to separate out the runout from the concentricity. Rolly's dad's method works but only for rough alignment. Similarly, using a ground test bar in the spindle taper isn't repeatable - even if you can find a quality test bar (which most test bars are not).
It is better to cut your own bar because done properly, that bar left in the jaws as originally cut, will be true to the axis of the spindle. The alignment of the head and bed becomes mostly a matter of eliminating taper and indicator differences.
Of course, the bed must be aligned first.
Oh yes, and as I recall, beyond about 8 inches, a schedule 80 pipe is better than a bar because gravity makes the solid bar bend too much from its own weight.
I'll see if I can find those discussions and link them here.
Here is another thread on the same subject. It isn't the one I was thinking of, but still lots of good discussion here.
Test bar
Edit - Link Fixed
imo too long and skinny, but i'll come in very handy for making cutters :). Almost anything can make a blank but be aware that stuff like drill rod is neither round or straight - it's centreless ground. It could still work, but you need turn it, not rely on its existing surface.
Agree pipe/tubing is a good choice, the material on the outside gives more rigidity per pound than the material on the inside.
What are you trying to test for?
The hairy guy is right, this has batted around with lots of discussion on it that would likely be helpful. I've done it both to align headstocks when reconditioning as well as to tweak leveling to take out a taper .... most what I have to contribute is here https://canadianhobbymetalworkers.com/threads/test-bar-again.8319/#post-121626
Hey Chris, I guess I should try to answer your question eh..... LOL!
I gotta start by saying that I've yet to see a YouTube video that covers all the bases. A few cover certain aspects well, but nothing I have ever seen covers the subject completely. So you might be better off forgetting what you saw.
I am whipping this together for you before I head out planting my fields today. So it might not be perfect. I will appreciate any feedback from knowledgeable members for any errors I make unintentionally, or anything I missed. It's one thing to write a quick summary and quite another to actually do a complete alignment.
Different kinds of lathes use different methods to line things up. Generally, it's done by bending and/or twisting the lathe in various way. Remember that everything is rubber.....
Some lathes have special alignment screws, some use the cabinet feet, some use bed feet, some use shims, and some are not really adjustable without scraping or shims or other more intensive means. In every case, it is an iterative process because most changes affect other changes. If your lathe can be adjusted, the following is just a guideline. It is only my guideline as others may have their own ways of doing it that may or may not be legitimate. The goal of lathe alignment is simply to ensure that your lathe can cut as close to cylindrical concentric (not conical) parts as possible across the length of the bed.
Step 1 - Remove any twist from your bed. This is the step that earned the term "levelling the lathe". You can usually use a precision level to evaluate and eliminate twist. The bed doesn't really have to be level. It just has to have the same "tilt" along its length from end to end. I prefer to put my level on the two way flats using precision blocks not on the V-ways. The small flat top of the v-ways are not always ground consistently. If you can't use flats, then use two v-blocks between the v-ways and the level. Don't use the small top of the v-ways unless you have no choice and if so be skeptical. And don't interchange the blocks - the rear block should be the rear block for all measurements, and the front block should be the front block etc. On a rare lathe, I have found that it isn't possible to untwist the bed without one of the feet being off the floor. That's ok. Just let it float but be aware that this particular lathe is gunna take a few weeks to level. It was "most probably" built level, so give it time to settle back the way it was built, and take a good look at other fasteners (oil pan, etc) to make sure that they are not fighting the process.
Step 2 - Align the tailstock up close to the head. I like to use tailstock alignment buttons. You can buy them or make them. Cut the chuck center in place so the center reflects the axis of the spindle and then don't move it. Many guys just use a bar between centers and work toward eliminating taper by centering the tailstock. If you use a long bar, be careful about what you are measuring - see other steps below.
Step 3 - Align your bed. (This assumes your bed isn't badly worn). You can put a known good bar between centers to measure and eliminate bed bend (you already did twist). These included hump back bed, sway back bed, bent in or out bed etc. Bent in or out is not common, nor is it easy to fix. But it's good to know if you have it. The process involves sweeping an indicator along the top and sides of a long perfectly cylindrical test bar held between centers and then evaluating why it deviates, if it does. This is a difficult step because it's so easy to misinterpret what the indicators show. Take your time and do it carefully. Study what you measure and ask yourself why.
Step 4 - Align the axis of the Spindle with the Axis of the bed. You don't want the spindle axis to point up or down or sideways relative to the axis of the bed. Chuck an 8" to 12" piece of schedule 80 pipe with an OD of 1" to 2" in the jaws of a chuck and try to make sure it is relatively stress free. (Note - I am working on longer bars to calculate and negate the effect of gravity, but I'm not ready to share yet.) Schedule 40 will work but it doesn't have as much meat to cut with....... and you will probably do a lot of cutting.
Begin by relieving the center of the bar to create a dumbbell. Then "shave" (extremely light cuts) the two near and far end lands very carefully and consistently. You don't want to bend the bar as you cut it. The goal is to align the head with the bed so it makes these two cuts identical both up and down and side to side despite their separation. If you suspect bed wear, you can cut 3 or 4 collars to help quantify the deviation and wear.
To repeat, this entire 4 step process is iterative. By its very nature you will not likely be able to do this like you normally make parts. The adjustments affect each other. The ideal alignment for every lathe will be different. However, by doing it, you will come to know what the strengths and weaknesses of your lathe's alignment are, and you can try to compensate for them as needed in use.
Edit - one final comment. Do not let the perfect be the enemy of the good. Even a less than ideal alignment can result in a lathe that can cut satisfactory parts in the hands of a hobby machinist who knows their lathe. The wear and tear that is almost inevitable in an older lathe is a part of its character. If you understand your lathe, and, it's strengths and weaknesses, you are waaaay further along than a fellow who just blindly assumes their new or old lathe is perfect.
Tubal Cain said I could use drill rod, there goes another $67 out the window.
I dug out an old shock absorber from a 1970 Datsun 240z, 1" dia, hard chrome, 16" usable length.
Will that work?
@Susquatch Whoa. Thanks, I'll get on right away.
