Lathe test bar
skippyelwell
I've purchased a 3ft piece of 3/4" tool steel/drill rod and am getting ready to make my own test bar to align the new lathe.
I've watched a couple of vids but I thought I would ask you guys before I start cutting if there is anything I should watch out for, tricks, tips?
Why cut ? Run an indicator instead.
The straightest rods I have found are hydraulic cylinder rods. They are also chromed and dead hard. Drill rod is nowhere near straight enough IMHO.
I scrounged some from a local equipment place that services farm machinery. Cutting to length was a job though.
We have had this debate on here before.
My short summary of those discussions are that running an indicator on a known good bar isn't good enough. It's too difficult to separate out the runout from the concentricity. Rolly's dad's method works but only for rough alignment. Similarly, using a ground test bar in the spindle taper isn't repeatable - even if you can find a quality test bar (which most test bars are not).
It is better to cut your own bar because done properly, that bar left in the jaws as originally cut, will be true to the axis of the spindle. The alignment of the head and bed becomes mostly a matter of eliminating taper and indicator differences.
Of course, the bed must be aligned first.
Oh yes, and as I recall, beyond about 8 inches, a schedule 80 pipe is better than a bar because gravity makes the solid bar bend too much from its own weight.
I'll see if I can find those discussions and link them here.
Here is another thread on the same subject. It isn't the one I was thinking of, but still lots of good discussion here.
Test bar
Edit - Link Fixed
imo too long and skinny, but i'll come in very handy for making cutters :). Almost anything can make a blank but be aware that stuff like drill rod is neither round or straight - it's centreless ground. It could still work, but you need turn it, not rely on its existing surface.
Agree pipe/tubing is a good choice, the material on the outside gives more rigidity per pound than the material on the inside.
What are you trying to test for?
The hairy guy is right, this has batted around with lots of discussion on it that would likely be helpful. I've done it both to align headstocks when reconditioning as well as to tweak leveling to take out a taper .... most what I have to contribute is here https://canadianhobbymetalworkers.com/threads/test-bar-again.8319/#post-121626
