JCDammeyer's 42 projects
I found out the other day that the ESP32 processor modules have a CAN bus. Apparently it's a clone of the SJA1000 from Philips but they can't call it CAN so they call TWAI (Two Wire Auto Interface).
The ESP32 outputs are 3.3V and need a CAN bus driver so I put together a small board with a 5V driver and resistors to level shift.
Here's the latest project finally working.
ESP32 DEVKIT1 running pins 4,5 out to a CAN bus level translator and the CAN bus goes out to an Olympic Ring Light #27 (500kbps). The blue thing is a USBCAN dongle to verify the correct messages are being sent.
The App, written in Delphi Object Pascal, sends out UDP packets to the ESP32 formatted in ACN1.31 which carries internally the DMX512A 513 bytes of data. It receives that, parses the data and updates the lamps over the CAN bus.
And the output from the ESP32 to the PC that shows it's getting the messages.
Received packet from : 192.168.0.137
For Universe #6
DMXPacketLength 513, DMXSlotStart 0, DMXSlotIncrement 1, DMX_RGBWI_CHANNELS Sending CAN Message
Now I can use Vixen Light Show Software to create the ACN1.31 messages. And it turns out DragonFly is delivering my five 3V CAN transceivers today some time.
In the past I've had to use hard wired Ethernet to make this work.
Great fun even if a bit frustrating.
Let's see... metalwork... hmmmmm... Ah. Yes! I soldered the adapter board.
For Universe #6
Yeah I'm thinking I'll turn the fan around. Even a bit of air circulation creating movement is probably good for the plants too simulating the real world.
My wife has starter plants growing in a couple of indoor greenhouses in our basement (not as fancy as yours). I sourced little fans to simulate wind which she says stimulates the plants and helps them grow. Lights are on a timer, she watches humidity and temp, have a little heater if necessary, and the light fixtures height are all adjustable because she says closer to the plants is better. Ok. I just supply the hardware technical support so she doesn't burn the house down.
In my last job I worked with managing, interpreting, reporting and acting on CANBUS messages from a variety of sensors. One of my get-to-it-someday projects is to interpret the CABUS messages in my vehicle, which tells me not just my speed, but the speed limit per the posted signs which the car's camera reads. I want to put a large display in the back window, clearly visible to tailgaters, along the lines of "The speed limit is XX". "My speed is XX" "What's your ^%$#! Problem, %$#!?"
Can you make/buy a "middle finger" light and wire it into your brake lights? Probably just as effective, in the back window
I have a Redboard (Ardunio clone) with a CAN module along with the proper pinout cable and connector for the connector to the car. Was able to monitor messages but found most of them are unknown and finding out what is what is really hard.
I ended up buying a commercial CAN message monitor which let's me reset fault codes etc.
What sort of CANBus stuff did you work on?
Nothing to do with vehicles. The company made dementia monitoring and nurse call systems for continuing care retirement residences. Fall detection, wander alarms, incontinence sensors, many other things all fed back to a central monitoring system to log and alert nurses and care staff. Also developed a smaller scale system that ran on a Beagle Board under Linux. The last thing I worked on before retiring was porting the Windows based (w/ SQL Server) legacy PC system over to Linux and PostgreSql.
Since the company had designed the system from the ground up, I didn't have to reverse engineer CanBus messages, just translate them to human meaningful form and act on them.
Yeah, the anti-tailgater messaging system.... I like the middle finger idea, easy to implement, but actually reading the legal and actual speed from the CanBus and letting the tailgater know exactly why I'm annoyed at them that has a certain appeal.
We previously had a Nissan Leaf, and someone had either reverse engineered or had access to the CanBus messages and built a blue tooth app ("Leafspy") which allowed you to look at battery life and the things that EV owners mostly care about. I don't know how available that stuff is for the Hyundai Kona we have now. I'd like to think it's in a service manual somewhere. In any case, that project is way down the list.
I mostly did work with industrial control systems starting in The Netherlands before there were CAN bus driver chips.
Later on all sorts of small projects.
The late Steve Corrigan, at Texas Instruments, who designed their CAN bus driver chips, sent me a wafer of CAN drivers sandwiched in glass and with a clock movement.
I decoded the CAN bus messages from the main CPU to an EPS (Electric Power Steering) module so that I could mimic the main CPU to trick the EPS into thinking it was in the original vehicle (I put it in a hot rod). The messages were simple, few and easy to decode. I used a $1, 8 pin uC to emulate the original messages, the main CPU did send speed messages, so the EPS would adjust the effort based on speed.
Eliminated about a hundred pounds of leaky, squeaky hydraulic crap.
Fun project.
I wonder if this is possible in a Deere tractor..... Standard code readers don't work. I'd love to be able to get at my tractor electronics.
Just had an issue this week with my 3pt hitch. Had no idea what was wrong and no time to figure it out. Plowing can't wait for winter so I had to take it to the dealer. It's not OBD compliant. It was just a sticky electronically controlled spool valve.
