Doggggboy
Doesn't at least one of you have a Vevor Mag Drill and a spare 1/2 inch steel plate?I was going to use the 1/2" mortising unit as suggested by Google AI as two staggered rows of 1/2" to make the 1". However when I did a test hole in the soft spruce I found the control was just not there. Too much vibration and the soft chips kept jamming up the chisel around the drill bit.
So instead I went with the 1" Forstner drill bit.
Discussions then went along the line of using a 1/2" router rounding bit to make the tenon edges curved. However once I started making square holes I initially was having fun so I kept at it. But then late last night my hand cramped up and I had to stop. By then it was to late to switch over.
I mean, come on.
