Alu was just a guess on my part. Could be totally wrong.
Awaiting details from Gary…
Using EM for small internal splines is doable as I did similar for similar projects - but it does not work too well for something that is ... big.
One could see whatever one could do some kind of indexed broaching. But it would take a long time.
There must be a way to do these things faster in a home shop!
No it will never leave the ground it is only for a test stand.
I watched this last night he makes the clapper tooling and broach, the spline is at 16:00
I'm not quite sure what you mean my 'end milling' the internal profile. Do you mean roughing out the mass before finishing to the (typically curved) profile. Or a custom cutter with the curved spline profile? How would you get that tool in & out of (guessing) 4" bore x 6" length when EM must spinning perpendicular to the ID surface?
