TorontoBuilder
i wasnt aware of that channel...Bah, forgot my personal favorite !
EverettsWorkshop
EverettsWorkshop
I belive Rob posts regularly on Instagram (I rarely check out Instagram, he has posted links to IG on his YT channel).I rank Robin Renzetti as number one on youtube. But I have one complaint, he rarely posts content so I don't get more viewing pleasure.
Another good vid.I remember the Sears gas station at Hillside.
Anyway. This thread is very interesting.
Please explain to someone who hasn't got a clue how you will flatten the stone once it's held in place.
And once the stone is flat where is it useful other than say sharpening a hand planer blade.
Another good vid.
The surface grinder with a diamond wheel does two things. Not only does it provide a precision ground "flat" surface, but it also removes the points from the abrasive bits held within the matrices.I am assuming that using a surface grinder works differently than using something like this https://www.leevalley.com/en-ca/sho...67-truing-stone-for-water-stones?item=08M1530 or wet dry paper on a surface plate? That is how I flatten my sharpening stones for my wood working hand tools.
This might be a stupid question but would just using a much finer grit stone do the same thing as far as having less bite? My only experience is with using stones for sharpening so I am trying to rap my head around the differences. I guess I should also ask are these stones different from sharpening stones? I mean before you grind them on the surface grinder.The surface grinder with a diamond wheel does two things. Not only does it provide a precision ground "flat" surface, but it also removes the points from the abrasive bits held within the matrices.
It is my understanding that other lesser abrasives cant do this laving the stones with too much bite into flats and grind them instead of floating over them
Flat Ground (or Ground Flat) Stones are used around machines for removing raised burrs & dings.The surface grinder with a diamond wheel does two things. Not only does it provide a precision ground "flat" surface, but it also removes the points from the abrasive bits held within the matrices.
Yes, but the flattened stones for sharpening chisels etc dont have the abrasives on the flat surface plane ground flat. The process merely strips out high abrasive particlesFlat Ground (or Ground Flat) Stones are used around machines for removing raised burrs & dings.
The “flattened” stones are used for sharpening chisels, plane blades, etc. so that the blades have straight, flat edges (and not slightly curved and/or concave/convex edges).
Two different processes to achieve two different results for two different uses.
To true & condition my water stones which re reserved for sharpening blades & tools etc. I'm real happy with this flattening stone.The “flattened” stones are used for sharpening chisels, plane blades, etc. so that the blades have straight, flat edges (and not slightly curved and/or concave/convex edges).
Less cleaving more cutting minutely without popping particles from the matrixMy friend went through making precision flat stones on his surface grinder like Renzetti etal. He said another variable that needs attention is the stone itself. He was using the correct diamond or CBN wheel (I cant recall which) and proper setup & DOC & feed etc. But many of the stones were not responding as well despite having the same nominal grit & AO makeup. I believe it was a Norton stone that worked in the end & possibly he got that info from Renzetti vid, not sure. The way he described it is the diamond is cleaving the grains to some degree, but mostly its about dislodging them from the binder matrix in a very controlled manner & that's what apparently varies by supplier. I have a set & they are a joy to use. Having said that, I wish there was someone local that I could drop my smaller stones for tuneup. They see the most use & get out of whack over time. I'm using cheapo Chinese diamond plate to flatten which works but not that great. I can feel the diamonds getting dull quite rapidly. (AliExpress specials).
I talked to Everett this week, and he is feeling guilty for being away. Young family, illness, and aging parents have taken all his time.Bah, forgot my personal favorite !
EverettsWorkshop
that's a sweet deal.
The jig looks perfect, no need for any sort of base.
A related question - how do you balance and true a diamond wheel?
Best instructions I've found I linked to above ..... but you're going to have to suffer through a video lol. Basically you manual balance it statically on a hub as best you cab get it, torque it down on a hub, use a dressing stick to remove resin, then grind steel (absorbs diamond) until the wheel is cutting all the way around.
Hey TB, where do you get your diamond wheels and which ones are they?
