It's the small 28T headstock drive gear depicted in this image. About all that I can tell you about it, is the following:
28 Teeth
Toothed portion is 0.385" wide (deep?).
The boss is 1.0" dia and stands 0.412" proud.
The shaft OD it mates to is 0.562"
The boss is drilled through to accept a shear pin that passes through the drive shaft and has a groove to accept a snap ring to capture the shear pin.
Willing to pay material and time (within reason) should you be able to manufacture such a thing for me.
I have the gear it mates to (which happens to be the same gear it's replacing) if that eliminates some guess work (i.e. the boss configuration, tooth profile etc).
Thanks,
