I would love to hear thoughts on this ad for material.
All I would say is try & check the alloy because some SS is not particularly great for hobby machines & you can waste a lot of time fighting mystery metal. Otherwise looks like a decent score.
Crankit
Round bar looks like 400ish grade SS from the look of the rusting, hard to tell on the square depending on how long it's been outside.
Perry
I know this post is a little old. The ad is still on kijiji and it does look like the material has been marked. Maybe the seller will take a few better photos of the markings. Might help you out.
I found this post searching mystery metal. I have a piece I'm trying to identify. There are a few markings on it but nothing stands out to me. Maybe the collective knowledge of the group here will figure the puzzle out.
Here are a couple images.
Looks like a stainless of some type. It had been outside for a longtime. There is a few markings that I can barely read. The top line is 1" T, next line 4" X ?? (48"). The piece is 1"thick by 4" and 48" long. The last line is probably the material spec. I see HT F?2302 , maybe HT F92302? The one inch sides have a hard crusted scale to them.
Cheers,
Brent H
It looks like stainless and it has been plasma cut off to that size. If the last numbers are 302 it is likely to be 302 stainless:
“Type 302 is an austenitic chromium-nickel stainless steel that is available in the annealed and cold worked conditions. Type 302 is a higher carbon, earlier version of Type 304 stainless steel, and many 302 applications have switched to Type 304 with the improvements in melting technology.”
Perry
Brent, that might be it. I never thought about the edge being cut, but that would answer the scale. I was searching around last night and came up with GH2302. A stainless alloy.
The HT might be heat treated?
