How to
Dennis R
I am trying to restore an old Canadian drill press, same as a Buffalo. I need to remove the only remaining down arm, which looks like a friction fit. Suggestions?
Yup nothing to loose but in my experience when heat is needed just propane is often not enough heat.
I believe on my drill press those arms are threaded in but it is of Asian origins
What do the other 2 holes look like Threaded or pressed?
If its truly stuck cut it off and drill new holes for new arms. I also think its threaded. On the other hand there are no flats on the handle for a wrench so maybe not?
If pressed and seized, Kroil (or your favorite penetraing oil) (I'd soak entire part for a week) followed by heat......
