How to measure high torque values?
a u joint clunk comes with serious vibrations, a clunk from excessive differential backlash wont, but i also think they fed you a line of sh!t about it being because the it was an s10 chassis (witch it is), it sounds more like that rear end was put together on a friday at 4 in the afternoon and maybe was at the extreme end of the spec for allowable backlash when it left the factory, and with some wear was probably out of spec, ive driven several s10's and s10 blazers, none had any audible clunk from the differential. That being said, excessive backlash on the diff of something low powered like a 4.3 s10 will likely not cause any catastrophic damage, im sure it would be a flintstone mobile and in the junkyard long before the diff let go
Mine only had ~ 60K on it when it was totaled; I’d have to scan a photo of what it looked like after it rolled into the ditch (surprisingly calm as I sat there waiting for things to stop spinning & rolling, and I was talking to 911 - hanging upside down - before the witnesses got to me).
There is too much interesting stuff on this thread!
First, let me echo Susquatch and say don't use anything except a manual tool if you care about the exact torque. Even the government via the NBC recognizes that any other method is too unreliable. Only the 'turn of the nut' method is acceptable for slip critical structural steel connections, and impact tools are the worst. Turn of the nut is easier to measure than the torque and leaves a visible trace for building inspectors. The thread pitch of the bolt gives the exact torque via a simple calculation
In addition to load cycling metal fatigue issues, pre-stressed connections can have another advantage. They don't move (strain) when external loads are applied - as long as those loads are within the stress envelope of course - because of course, the strain has already happened! This technique is frequently used when affixing components in vibration and shock environments.
There is a lot more to say, but I am being paged by my better half
definitely a Friday at 4pm assembly then, But on the bright side you made it out of a roll over!
@David do you have any unusual tire wear ? i just skimmed a video changing a lca, i see those lca frame bushings are in a slotted hole without a cam bolt/cam washer, if those suckers are not fully torqued you would get some clunks as lca moves around driving, you're alignment would be all over the place as well giving you some weird tire wear. It would likely be torqued enough that a tire wiggle wont show it, but if you get under there with a pry bar and you can move that lca bushing around in the frame mount that could be your culprit, at least another free item to check
Tires are brand new and I've probably only put maybe 1000kms on the truck since I bought it in September. Haven't noticed any odd wear patterns and it drives exactly as I would expect.
I did notice today that the clunk only happens on straights, never around a corner which leads me to suspect the sway bar links.
