How Not to Produce a Simple Wood Pattern
carrdo
Hi All,
Well, it started off very badly.
As I had the right (odd size commercial hardwood dowel of approx.1-3/32" dia) I said right, I will use that for the two cylinder pieces. So, I got to the stage shown in photo 30 when I started to measure things more closely and I discovered that this "round" dowel was really egg shaped and by a lot!
And, as well, after further calculations on how deep the two cylinder cutouts in the base block needed to be, the base block turned out to be too thin so scrap everything shown and start over again.
So, square up a new thicker base block and then carefully layout where the two cylinders needed to be (1-3/16" centre to centre with a 9/32" deep cutout). And, in addition, since everything needed to be centered lengthwise, this took a while.
To rough out the two cylinder cutouts, I had a 1" dia. ball end mill and end mill holder. This was spotted on each cylinder centre line in turn as shown in photos 33, 34. Because the base block wood was just some unknown (a no, no) scrap wood which I had, I had to proceed very slowly and cautiously so as not to break the edges of the wood when the end mill entered and exited the piece. Some very minor splintering did occur but nothing which could not be fixed.
The only casualty; a lot of lost time doing everything the hard way again.
to be continued.
Hi All,
To finish the cutouts in the base block, I switched to a boring head tool as seen in photo 35. To ensure everything remained square in both planes, I used the setup shown in photo 36. Afterwards, I checked the accuracy of the work and to my surprise the vernier height gauge shows both cylinder heights dead equal and the spacing was that way also.
Again, the only casualty was the amount of time taken and the fancy machining involved.
to be continued.
Hi David,
This will be the new double steam or air brake cylinder pattern for my 3/4" scale Hoffman NYC Hudson live steam locomotive. I now have the design for this and Carl Hoffman never had the casting for it. The original Hoffman brake cylinder drawing shows a single cylinder only which is based on a UK (appears to be from a Don Young) design.
The Hoffman brake cylinder drawing, as originally supplied, leaves much to be desired and is not prototype for either the NYC Hudson or for North American practice.
I will have to make a new model print to suit what I am producing as well.
Very cool. Definitely interested in seeing how you progress this!
Hi All,
Pushing on to where I am now.
The two cylinder pieces were first glued to the base block cutouts with some white glue letting the glue dry for about 24 hours and then the contour fillets were added in small thin incremental layers (approx. 4 in total). I let the filler dry for at least 24 hours before adding the next layer. I used standard plastic wood because it was cheap but in retrospect I maybe should have used something better like Bondo.
The next mistake made was to belt sand in the pattern draft (3 degree taper) on each long side. Don't do this as then it becomes very difficult to hold the partially made pattern straight in the vise for all of the contouring operations. Because of this, I had to keep reversing the tilted pattern in the vise after each pass of the ball end mill to end up with a straight cut.
Contouring the pattern plastic wood fillets and contours and blending them in to produce a seamless curve was undertaken using various diameter ball end mills and then finishing the continuous curves by very careful riffler and regular filing. It was quite concentrated and tense work as I had never attempted to do it this way before. The plastic wood, even in its hardened state, is quite weak and turns into a fine soft powder under end milling. I ran the mill at its highest speed and took only very light cuts (0.003" DOC) while feeding the end mill VERY slowly across the work taking particular care when entering or exiting the workpiece. Even so, there was some minor fracturing of the plastic wood filler at the sharp side edges which were then patched up and left to harden. This is where I think something like Bondo would have worked better. For the two cylinder side fillets the pattern piece was tilted 3 degrees (and sometimes more) in the vise using the reversal method to achieve a straight across cut to remove almost all of the excess fillet material and then blend it all in with careful hand filing.
Still have the all sides final draft to do.
As welI, I will try to harden the plastic wood fillets and contours (before the final shellac coating is applied and painting) to prevent damage in these areas when sand is rammed around the pattern as the plastic wood filler remains quite soft and weak.
Live and learn.
to be continued.
Hi All,
The Hoffman Hudson single steam brake cylinder pattern, casting and machined cylinder made by me decades ago as shown on the Hoffman main drivers brake print but never produced by Hoffman. The brake system as drawn is incomplete and cannot work and will have to be modified (many new details need to be added). Another job to do when and if I get around to it.
An operational sectional view of a double brake cylinder on a related live steam 3/4" scale American locomotive print for comparison. This is only part of the overall braking system, the complex brake valve in the cab being another critical and very interesting component needed.
  • 48 The Hoffman Hudson Single Cylinder Steam Brake Pattern Raw Casting and Machined Brake Cylin...jpg
Hi All,
Starting to draw the double brake cylinder machining drawing. I am a dinosaur as I do drafting the old fashioned way on a board as I was never able to master CAD.
Due to my wonky eyes, I need the Rube Goldberg lighting setup shown to avoid casting shadows but I do need proper overhead drafting illumination custom suited to the drawing board I am using. I also use the OptiVisor when drafting small mechanical details like this.
Boy, am I slow, I could never work in industry where everything needs to be produced yesterday. But on the other hand, my drawings are correct and can be machined exactly the way they are drawn unlike many other drawings I have encountered by persons who should know better (details referred to not shown or are incorrect, half drawn mechanisms that cannot possibly function that way, threads shown threaded right up to a square shoulder or right to the bottom of a blind hole, it goes on and on.
Time to stop griping.
Hi All,
I finally finished the double brake cylinder drawing. What a relief!
I still can do drawings like this (despite my printing scratch) but it really tires me both physically and mentally now.
The 2D sketch and the Drawing dimensioning in Autocad Fusion is a great investment of time as the payback is greatly improved productivity. It's free for hobbyists with some minor limitations.
Does anyone else have trouble with the images in the thread. I can't get them to open in 3 different browsers, just says 'image not found'.
Very nice job on the drawing. I've always had an affinity for old hand drawn prints. I'm taking my first ever manual drafting class right now, so maybe I'll start to do some hand drawing for projects in the future too.....
Hi All,
What is this crazy doing now.
Milling a 1/8" wide shallow slot approximately 0.050" deep in a 4.5" long piece of scrap aluminum as seen in photo 50. The slot was carefully made to be a good tap fit for the 1/8" square copper work piece as seen in photo 51. The copper has been heated and annealed all over several times so that it is dead soft and malleable. It came as a bent up mess so the first operation was to straighten it out by heating it red hot and hammering it (with a non metallic hammer) straight in progressive steps against a flat surface.
I went and paid a crazy price for this one foot long piece of square copper as it is not available anywhere in Canada (as far as I know) and only on special order from a jewellery supply in the USA. The shallow slot can be used to further straighten out the copper although this is not its primary purpose.
I have no idea if what I am about to try will work as I have never done anything like this before so in my head I have plan B if everything goes south.
to be continued.
Hi All,
Another Rube Goldberg clamping arrangement needed so I can move forward on this project. The angle vise lugs do not quite align with the tee slots on the table of the Millrite. Trying to achieve universality and interchangeability between all of the different holding units here is proving to be quite a challenge.
The bottom angle piece has probably now been modified three times to suit the various clamping needs on various projects made over the decades. I can't even remember what it was originally made for anymore.
Hi All,
Now you are going to see what this crazy is trying to do.
The first thing to note is I didn't need or use my angle vise setup and special clamping at all but it will be very useful for any future setups involving this unit. Instead, I used a standard 3 degree tapered end mill in the regular mill vise for what I was trying to achieve. This also proved to be a mistake as one should bend the copper first and, if successful, only put the 3 degree taper in after bending. But since I had never done anything like this before, live and learn.
The tapering operation shown in photo 701 is NOT recommended. It is extremely hazardous as there is nothing holding the copper straight piece to the aluminum base plate other than the close fit of the workpiece in the shallow milled slot. And the tapering operation will compromise the slot. I did it this way because I was desperate. By taking extremely light cuts of only 0.001"- 0.002" per pass and running the tapered end mill as fast as the VCR allowed, somehow I got away with it but it was extremely tense. One needs to employ extremely strong glue in addition to the mechanical fit in the holding/aligning slot and/or construct a travelling hold down bearing on the top surface of the workpiece with the cutter in the middle. I have, in my head, how to make such a device but for making just two parts it was something I just didn't want to get into.
Anyway, the square copper pieces need to be formed to conform to the upper curve of the wooden pattern to form end ribs as this is what the prototype brake cylinder has. Again, this was all done through hand forming and I had no Idea if I could achieve anything this way or not. Well, all I can say is, if you go this route, heat the hell out of the copper to leave it the consistency of soft butter as this is what it will take to form (in many stages) the continuous compound curve needed. It was done by tapping it around various diameter round bars and some times even by hand bending. But as soon as one starts to feel any resistance, heat up the copper red hot again. It took about a dozen heatings to get it finally to the shape shown in photo 704 and I am not finished yet.
Pure copper is a very interesting material to work with and it can take almost any shape if one knows how to form it.
PS: Propane and a propane torch is an ideal way to heat copper as it is very difficult to overheat the copper using propane.
to be continued.
