This is almost too simple to deserve a post - but once you’ve tried it, then it will become standard procedure.
I’ve been doing this since i got my hot saw a few years ago (CanTire with 14” basic abrasive wheel). After a dozen cuts on small angle the saw starts to substantially slow down. This happens much much sooner if cutting thicker stock or heavy tubing.
Use a grinding wheel dresser to give the abrasive wheel new life. (the disc type in the photo)
Cutting speed will double and it’s much less likely to trip the breaker. (It takes 15 to 30 seconds and so far it doesn’t seem to affect the life of the abrasive wheel but the dresser wears pretty quickly)
PS. Not sure - but maybe a more expensive and higher quality abrasive wheel will not benefit as much.
