you said the wall thickness was .065?
I forget to say it must be expand for about 2 inch deep to be at the write place.
Here are my thoughts on why it happens to be a coincidence, .065 is a common wall thickness, the photo also looks like pipe could be thin enough to be .065, also as an aircraft part I could easily see that thickness of tubing for weight reasons, I have a feeling he may be trying to slip this pipe over another same size pipe
Ho yes this might be good
I know the wall is .065 thick and the inside now .875 and must be open to .940 so I say .940 -.875 = .065 is that correct ?He did say that. But I'm not sure that's what he meant. He later said that the ID difference was 0.065. That math is correct. It seems like a big coincidence that this is also the thickness of the pipe. French translation may be an issue here.
@Marc Moreau - can you please provide dimensions for the pipe you want to expand so we know what you need?
Wrong guy?That makes perfect sense to me. Let's see what @Dan Dubeau says......
If that is the case, then why not shrink the other end instead of expanding it? That's a LOT EASIER to do!
I have an impact Snap-On deep socket 15 mm that fit perfect inside the original bar. I want to try to heat the tube and use my hammer to push it inside ?
Ya, sorry about that.Wrong guy?
No worries. Got the notification then read, re read the thread a few times wondering if I had posted something, and it got deleted, or if I deleted it. Wasn't drunk posting so I ruled that out, and haven't hit my head in a while, so I ruled that out tooYa, sorry about that.
OkYou will probabaly destroy the tube trying to hammer a socket in the end, it doesn't take much to kink a pipe that thin
No you can't because of the shape this is made like bicycle handle. I will go the way a member say before weld a sleeve over and grind the inside after.Would it be possible to put a threaded rod through the tube, lock the side opposite of the swage with a washer and nut. Swage side with the swage socket, washer, nut and use an impact driver to drive the swage socket.
