Hendey 12 inch Shaper
Collector
Hi guys I have had this for years waiting to retire to work on it looks like it’s about time now. Does anyone have one. It was damaged and the tool head broken off and lost. So need to make one. Would like to have a couple pictures or a head of a donor machine. Made around 1955.
Hi guys
Had some time to draw up what I think will work for the missing parts. I printed the parts. Which gives a good visual start before going to metal parts. I can use these to fit the mating part on the shaper. The screw is bent so I will cut it off and make the top part to socket into the threaded with loctite and pin.
Its a pretty machine, looks like it has all the bells and whistles too!
One comment and maybe its just the images or my eyes, but it looks to me like the dovetail slide component is a bit too thin so its aspect ratio is off? Maybe in the actual parts you could just make it out of thicker material? Its so neat to see a 12 inch shaper with all the conveniences.
Some pictures of the machining of parts. For the tool slide. Using a slotter milling machine boring mill so far all good.
