someidiot
Well-Known Dismemberer
Okay, so I get the idea behind the .STL file for describing solid objects, and that's the format that the "test rook" model supplied by Elegoo comes in - the printer reads the file and spits out the object (Imagine taking the printer, a bottle of resin, and a 12V solar panel back 200 years - "Any sufficiently advanced technology is indistinguishable from magic"). And I get that there's "slicer" software that takes the 3D model and splits it into the layers appropriate for printing.
But what I don't get is how these pieces fit together. How can the .STL file describe both an object and the slices you wish to render it as - unless each layer is represented as a separate object in the file and they're simply printed in order? So does that mean there are two versions of .STL files - unsliced and sliced - and that the slicing software turns the former into the latter?
I'm led to the question because as soon as I got this thing running, my daughter expressed interest in wanting to print a bunch of small frobs (details unimportant) for which there are ample free models available - but apparently for filament printers (rather than resin), which implies that the model would have to be resliced (i.e. resampled) for the thinner slices the latter renders. Or do I really misunderstand this?
