Megar arc 5040dd
I need some advice and opinions on what material to use for a table saw arbor nut? The nut that holds the blade on the arbor of my table saw stripped out a while back. A replacement was nonexistent. It is a lesft hand 5/8" 18 acme. I ordered a tap over a month ago and it finally arrived to day so now I can make a new nut finally. I just don't know what I should make it out of. The last nut was made of steel and after about 30 years of use the threads basically pulled out of the nut. I am worried that if I make the next nut out of steel then I run the risk of damaging or wearing out the threads on the arbor and that would be a real pain to take apart and replace. But I also need it to be strong enough that it doesn't just pull the threads out of the new nut right away. My first that was maybe brass but or some type of bronze?
Please I am open to all suggestions and advice.
