Hand powered shaper
It's taken me a while to clear out other less fun projects but started in on this 2 days ago and just finished today.
The original deep blue paint wasn't great to begin with and most of it came off just using dish soap on the parts, while hunting around to find a matching paint I thought I would try Dykem Blue layout fluid and it is a perfect match.
Don't know how long it will last but it looks good at the moment.
This shaper has seen quite a bit of use, I had to make of some thin brass shim washers to take up the slack in the pull arm.
This is the best I could get on cast iron,
soft aluminum,
and mild steel,
I tried 3 different bits but the results were similarly rough, I wasn't expecting a smooth finish but was hoping for something a little better. I'll play with the gibs a bit more, see if I can improve the finish.
That would be perfect for my needs (and my small Shop). @Chicken lights : can you swing by, pick this up and drop it off at my Shop your next trip South? I'll buy Lunch.
Hey Skippy! That is the coolest darn thing I've seen in a very long while. I love it! Very well done!
You should try a shear tool if you didn't already. @140mower got me to try that. It took some effort to get it right, but I'm now sold on it. I think there is a pretty good chance that it would clobber your chatter. Makes a better finish regardless so well worth trying.
Yeah. If you can, try checking some OLD Machinist manuals and handbooks, and pay close attention to the types of geometry that they recommended for shaper and planer tools. Many of those were forged most of the way to shape, out of basic High Carbon Steel, before being sharpened for use, but the geometry they used for 'slow speed' machining, allowed the industrial age to advance!
They used a lot of rake angles to one side or other, almost no, flat on top, cutting tools.
Not saying to not play with the gibs, as they, in the end, determine just how much freedom the moving parts have to move about as the tool tries to chatter, but these are small, none too heavily built machines, subject to flex, by nature of their size, and if you handicap the machine with a tool geometry that forces it to take fullest advantage of the clearances and the ability to flex, the machine is gonna do both...
