Hand powered shaper
Oooo, you got the vise for it, nice score.
Mines a little older I think, there is no #1 or #2 cast into it.
Under all the dirt and age there should be very dark blue paint.
I'm only assuming it's a #1 from the pictures on the lathes.uk.co site
It's taken me a while to clear out other less fun projects but started in on this 2 days ago and just finished today.
The original deep blue paint wasn't great to begin with and most of it came off just using dish soap on the parts, while hunting around to find a matching paint I thought I would try Dykem Blue layout fluid and it is a perfect match.
Don't know how long it will last but it looks good at the moment.
This shaper has seen quite a bit of use, I had to make of some thin brass shim washers to take up the slack in the pull arm.
This is the best I could get on cast iron,
soft aluminum,
and mild steel,
I tried 3 different bits but the results were similarly rough, I wasn't expecting a smooth finish but was hoping for something a little better. I'll play with the gibs a bit more, see if I can improve the finish.
That would be perfect for my needs (and my small Shop). @Chicken lights : can you swing by, pick this up and drop it off at my Shop your next trip South? I'll buy Lunch.
