Good source for link belts?
slow-poke
I have yet to try the fancy link belts, seems like people using them feel they are better than the old V-belts.
I do notice my V-belts do take a shape.
can anyone recommend a good Canadian source?
Be aware they are directional, They will run in both directions but could cause snagging or vibration in reverse.
I also found they did not perform as well at transmitting power, tested ( machinery in the field ) and not on a lathe or mill.
They did tend to run quieter then regular nylon/rubber carcass.
leevalley has some or perhaps amazon.
Gluck
Gluck
Can you please expand on your comment "not on a mill"
I was thinking for my drill press and possibly mill.
I think he meant had not power tested on a mill or lathe.
I get link belts at Lee Valley. Not cheap but very effective.
You are correct. Sorry the wording was improper.
My exp has been on machinery in the field. Not on machinery in the shop. Like a mill or lathe.
They run a lot smoother than regular V-belts. I have three regular belts, two are new, but they all run thumpy on my lathe where as the link belt is very smooth. They will stretch a bit as they settle so you will need to adjust the length after a bit of running.
LV only shows the one size but KMS has three sizes.
I had them on my old mill/lathe combination and liked them. Apparently because of the link structure the 60 cycle vibration that a motor can generate is no transmitted through the belt like a solid belt will do. I bought mine from Busy Bee. They were Power Twist.
I personally like them, they dampen vibration and find they have less slip. I know that by absorbing vibration there is a little power loss but I'll accept that for less vibration.
I am into the AMMEGA Megadyne facility every other week.
They supply custom & standard V, cog and flat belts for a wide variety of applications.
If you send me the specifications, I can pass it onto their Design Engineers.
It may take a few weeks, but I will stay after them.
I didn't know that either. That is a pretty serious disadvantage of them on alot of machinery.
I do however have the perfect application for one link belt...on a 50+ year old table saw that probably has the original belt on it and it gets turned on only a few times a year. The belt always runs rough and thumps until it looses the shape from sitting for so long. Too bad I was so cheap.
I've resisted putting link belts on my Unisaw because to do so would cost more than I paid for the saw.
I did have a look at MEGADYNE’s website . . .
They have a whole catalogue of Accu-Link® belts.
I use them on my 14x60 lathe, belt sander and horizontal bandsaw. The bandsaw is in an unheated garage. The standard V belt would thump and bounce. The link belt is smooth regardless of temperature. I have run them both ways without problem. I did not know they were directional at first.
