Are you making this out of solid wood? Drawer bottoms of metal? Etc etc
The chest bottom and lid will be a mix of birch plywood with hand cut thick veneer and solid wood edge banding treatments for the structural stability. I'm undecided on the sides, we have so much maple I don't need to cut veneered panels, but I'm super frugal, and I like dimensional stability.. so veneered plywood with edge banding makes a lot of sense too. What to do what to do...
Speaking of edge banding, woodpecker makes a very good but expensive router bit set so you can use tongue and groove to affix edge boards from very wide to almost invisible edge. I'm using it to make a twist on the traditional gerstner drawer bead.
The drawers will be solid maple sides, face and backs, with plywood bottoms. The drawer slides will be stabilized maple so they wont wear out in my lifetime. No metal bottoms, since I want wood mass to dampen fluctuations in humidity. For this reason the interiors of the drawers, lid, sides and front panel will not be sealed.
The drawer pulls like the accents of the drawer faces will be torrefied maple that is stabilized and dyed midnight black using cactus juice.
I wish I had an aluminum foundry permanently set up, so I could cast corner protectors from aluminum then bead blast them and anodize them black. I will try to make such protectors next summer, but can 3D print temporary ones for now.
