Attached is the FreeCAD file for the belt sander I am working on. I have not mastered moving objects around based on the plane, ie trying to move the drive motor forward while the frame is back. I have watched some videos on it but lost it again. But since there are a couple of you looking at this thread,
I thought I would post what I have so far and ask for critique. The drawing did what I wanted, and that was, to allow me to determine how long to make arms and parts, and if I was getting close to a 72" path, so all good there. Not shown but I used the ruler to measure distances, then old school, marked them down on my printed paper. I will get back to improving the diagram as I progress up the CAD learning curve but now, off to grind and cut metal...
Couple questions though...
Is my general idea/layout correct? Every part has its own, well, part sketch I guess? couple times I drew some sketches but then when I went to pad them, I was told no multiple pads.
Things missing (not required at this time) are wheel brackets, tension arm bracket, etc.
The posts (stand) are not attached to the top bar, but just laid out with a reference to the center using vertical and horizontal distances (as are all parts I guess) That part I get, although I think some need to be coincident somehow? or do they?
When I look at the top view, you will see everything is laying on the y plane. That is the part I am trying to get around. I tried shifting reference points, datum planes, points, ...but not quite got my head there. I watched a vid yesterday morning, thought I had it, but no..... Kind of like a golf coach...has you straight down the range when with you, then back to slicing when he leaves...
Anyways, something to look at if you are interested.
Thanks
Cheers,
