Force GL - 300 C x 914
Has anyone owned or operated a Force GL - 300 C x 914 lathe? My offer was accepted for one outside of Edmonton. Deposit is being put down now, and just wanted some insight on this import machine.
Didn't House Of Tools use the Force name on some of their stuff at one time? Looks like one of the many imported machines as YotaBota says. Congrats.
Thanks gents, will post pics once I get the machine in a few days. This will replace my Clausing that I just got fully operational thanks to RobinHoods advice.
Looks very similar to the lathe we had at the high school where I taught, Force name and everything. It was a pretty typical import 12x36, came from the House of Tools. Worked well enough, but make sure the quick change gear box for threading and power feed is kept lubed, I had that thing apart a few times on the school lathe, cleaning up shafts and bores when the kids wouldn't lube the machine before using it. Shafts are steel running on the castings with oil drip holes holding string wicks. The one at the school also had a plastic idler gear in the gear train from spindle to quick change box, it got replaced a few times too, including the times when the quick change piled up.
If a similar one (for the most part) survived my kids when I was teaching, you should be fine, lol!
I used to own one of those. I still have the manual as a pdf and a bunch of data on the internal gearing if you want it. Just PM me. PeterT linked to my for-sale thread above. I was happy with it. I only sold it to upgrade to a larger machine that I got a good deal on. The old machine made several of the replacement parts that were broken on its replacement.
Hi John, any chance I could get a copy of this pdf? Thanks
Hi John,
I sure could use a copy of the manual, still have it?
ronee
Hi John,
ronee
Lathe backup and running. Turned out to be the Emergency Stop Switch. It had seized up in stop mode, this despite the door panel sketch showing that it had the proper voltages present.
Just as well I was able to get it taken apart and sort of working as $135 bucks is a bit much for a new switch.
That and a VDF is not an option for a single phase motor as used on the Force/King machines. $5000 bucks for a new King!
