TheLocalDrunk
Active Member
AND I started making parts that actually DO something and work the way it was intended.
To most of you this is silly simple, but again for me, it is all ground breaking
First I needed to make a thread adapter.
Pretty simple, M12x1.25 on one side and 1/2-20 (or 13) on the other side.
What I learned from this, is that twist drill bits are not accurate at all
And they tend to oversize the hole.
Also learned that I need to learn to make my own tiny boring bars and how to use it.
Next was a couple of plates.
It seemed simple enough, but I learned that either my DRO is sticking or I have WAY too much slop in my table on my mill. It is close enough to what I needed by some of my measurements were off by 10 thou which I need to fix and clean up.
Here is the finished pieces in action
YAAAA it did something!
