They are angled. You get quite a positive grip when you tighten down.Just happened to be on another forum & saw this. Is it the camera angle or are the serration steps not angled inward a bit from 90-deg steps?
I thought I read somewhere the steps are actually slightly more than 90-deg so they self stabilize & don't slip? Or maybe that's what they are supposed to be & mine aren't? LOL. But I may be hallucinating there.
Yes they are, believe if you go to the machinery handbook, they give you the specs.I have 3 sets of different sizes purchased over time to fit different sizes of t-slots. All are inexpensive bargain sets. If I recall correctly, one is KBCTools, one is princess auto, and the other is amazon. The serrated steps on ALL of them are canted downward (80 degrees or so) such that they self align and won't ever fall off.
I bought only the blocks I needed, not a whole set. I have learned not to buy more than I need, it just collects and becomes a storage problem. If it turns out that I need a few more studs or blcks, I know where to get them.I was looking at the prices on kstooling for TECO ... holy. I can't afford $461 for a clamp set. That's list but assuming 30% off it's still a lot. https://ktstooling.com/catalogue/product/466459
Making your own is making more sense. 3/8 ready rod. a bunch of 1x3/4 square bar for clamps. T nuts ok. The trickier part is the blocks with the nice interlocking teeth. I suppose one could just use stack blocks. A pile of 1.5 x 1.5 by 1/2 flat blocks with a hole in the middle for a threaded rod.
I believe mine look just like that also. I will try to get a puck this morning to confirm.Just happened to be on another forum & saw this. Is it the camera angle or are the serration steps not angled inward a bit from 90-deg steps?
Ha ha I never noticed that either, it probably happened on the boat over from China. I can just about guarantee that it didn't start or progress in my shop.It's amazing what you see in a photo that you never noticed before.....
If I were you I'd get some oil or corrosion protection onto your blocks as soon as possible. Best to check the rest of your set too. Otherwise it will only get worse.
Personally, I recommend WD40 Corrosion Inhibitor or Liquid Wrench Rust Inhibitor. They are both expensive but so are your tools.....
Almost anything is better than nothing.
Phew, I checked the T-nuts I purchased and the stud can‘t be threaded through it.…cheap ones) be aware that as you tighten you can drive the stud or screw through the nut into the surface below the slots… Well made ones have this so don't tap it out unless required, it is there intentionally.
Just be VERY careful not to over torque them. A piece of broken T-slot on your mill table will cause extreme profanity and self abuse cuz you gotta look at it every time you use your mill......
Or the shaper table..... It was this way when I got it and I never met the meat-head that did it, but I have cursed him, his family and the pet chicken more than a few times.....![]()
I can’t imagine how upset I’d be if I broke a T-slot on the mills table…
Thanks for pointing that out @Degen
Looks like you could use a really good welder who could fix the table and then re-machine the slot.
I do have t-nuts that are through tapped but I use them with allen bolts for fixed depth. The others that I have used are Red Locktite in place with the studs, specific application.
Isn’t a ripped table on a shaper a fairly common thing? One mistake in the shaper feed - it hits the vise and, rips the whole thing off the table t nuts and table slots included?
I have considered that, but I have too many projects on the go now, I think I would rather put the time and energy into the bigger shaper and when it's done, let this one become someone else's project.... In the meantime I have been able to clamp around the breakout.Looks like you could use a really good welder who could fix the table and then re-machine the slot.
Not sure how common it is, maybe more of a problem with a bigger more powerful one. I have screwed up and taken too big of a cut before and all I managed was to slip the belts when things came to a crashing stop. The profile of the hole to me looks like the tee nut was jacked up and through the tee slot. Thankfully the rest of the machine has enough wear on it that it doesn't upset me as much as it could have, I could have put a curse on his horse and dog as well.Isn’t a ripped table on a shaper a fairly common thing? One mistake in the shaper feed - it hits the vise and, rips the whole thing off the table t nuts and table slots included?
