Boshield T-9?I'd love to find a light grease or spray lubricant that could be applied to internal or external parts that would last 20 years or so without becoming a problem of its own.
Yeah, I finally figured out that it really is a Brown & Sharpe #10 taper. After I got the crud cleaned out, I could see that the Morse taper sleeve I was using for testing was not engaged at the small end.All the Brown and Sharpe type dividing heads I have used have a Brown and Sharpe taper in the spindle, usually a 9 B&S, little ones have a #7 B&S.
I thought it was 2-1/4 inch diameter by 4-1/2 threads per inch. I remember checking the threads with a 60 degree 4.5 tpi gauge and I thought it fit properly. I'd expected it to be 2-1/4 by 8 tpi. I remember it was 4.5 tpi because that is not a thread pitch that my lathe is listed as being capable of. However, since the lathe will do 9 tpi, I though it could also do 4.5 by substituting one of the gears in the train.@trlvn I've got a question about this head for you. Do you recall what the spindle threads are? Because, and I really hope I'm wrong, they measure out at 55 degrees... making them....whitworth [style] threads!?!?!?! They also measure at 2.280" / 57.912mm, so that's different. Who built these things?
I can cut 4.5 TPI on my lathe, I've just never heard of such a beast.
Never seen it on any of our stuff! We are HP limited by field size around here. Biggest clear field we've got is only 42 Acres, and we farm a bunch as small as 1.2. Biggest we've got is 112HP at the moment, with slightly undersized implements to match... We seem to do it the very hard way! lol.You need to take some time off and come help me fix farm stuff. Lots of huge stuff in that world!
I'm in Haldimand County.Not quite that bad here, but my own machinery is prolly the same as yours. My big tractor is 125HP. So my stuff is prolly similar to yours. But I don't just fix my own. I am the local machinist for the entire township. When new parts cost 10 grand, the stuff the old guy makes looks pretty darn good!
Don't know how I missed that you farmed! I've added that to my mental picture of you..... LOL!
I know you are in Southern Ontario. I think I recall Guelph or so. Where abouts are you?
thats a garden patch at our place🙂farm a bunch as small as 1.2.
Soaking in Coca Cola is a popular method of de tarnishing and brightening up old Beryllium Copper golf clubs. Never heard about it being used for de rusting steel, But I wouldn't be surprised if it's been tried before.Just saw this, about the de rusting of your unit, made me think that Id heard that one can soak something in cocacola and it will de rust.
Has anyone had any experience with this or is it just a myth?
Thanks
Hmmmm, I always wondered that about you..... 😱 😛 😉We had weed patches bigger'n that...
Canadian thistle, not Toledo Window Box...Hmmmm, I always wondered that about you..... 😱 😛 😉
