Delrin source?
Actually it would be great if you could give us a heads up when they have a large selection in stock. I might make the trip all the way from Hamilton if I knew they had it. Don't know of anything comparable in Hamilton. National Surplus in Hamilton apparently closed its doors last year.
I took a detour today to check out KW surplus and unfortunately must report they not only had no Delrin but had no other plastics. A small amount of plexiglass but nothing else.
Odd. They have always had lots that for many years.
Maybe the plastic shop they got it from went under.
they had blocks of wood in the rack they used to keep it in.
I’ve used it for calibration cylinders in a gas/liquid measurement system, since it’s easy to machine, holds tight tolerances, similar dielectric properties to Teflon, and doesn’t absorb water. Currently making a prototype multi-bit screwdriver using Delrin for the bit holder/handle, much cleaner to machine than ABS or PVC, doesn‘t shatter when cold or when I drop it. Altogether really nice stuff to machine.
I've purchased it at Industrial Plastics and Paints in Calgary in the past. I know they have locations in B.C. I used to buy from them in Vancouver.
There is a source of Delrin in Kitchener.
Piedmont Plastics on Trillium Drive.
See the listing here.
Spaenaur will also stock some types of UHMW.
LenVW
plasticblocks.com does have DELRIN.
Use their ‘search window’ to look for … Acetal .
(DELRIN is a product name that Dupont Plastics has trademark’d).
Late to the party here but Plastic World in the GTA is a great source. Plasticworld.ca - only catch is you have to call or email to see what's in stock. A little cumbersome in today's world but they will cut to any size and have a lot of stock in both white and black.
Yes I can likely get it, question becomes are you willing to price. If you are stuck let me know and I'll try a few of my sources in the GTA.
