DavidR8's shop shenanigans
David
Scrap maker
Now that my shop is nearer to being sorted out I thought I'd start a general project thread for stuff I'm bashing away at. It won't be all metal work as I dabble in a few mediums, all mediocre to medium well ;)
I’ve been working on an ensuite bath.
Built in cabinetry is near the end of the job.
Framing in and finishing work left undone by a previous owner.
After working in my reconfigured shop I came to the conclusion that the configuration that worked on paper, didn’t work in reality.
So I spent the day moving the mill and lathe, swapping them into the spots previously occupied by my tablesaw and other woodworking machines.
Now I can easily access my saw which was previously a real bear to use.
The saw used to live along this wall and I would swing it out to use it. Problem was that I couldn’t get by the thing. Plus I had no way to use the dust collector so it made a hellacious mess.
So now the mill and lathe are on this wall.
@David-R8, do you have any idea how much your mill weighs ?
Did you move your mill with your shop crane, lifting straps, and stand attached ?
What strength and length are your lifting straps being used with your lathe ?
To lift your mill which pin hole position was your shop crane, 1/2 ton ?
Hi Dusty, the mill is a 1980 Long Chang and comparing it to other RF30 mills it has beefier castings. I did move it with the stand (which is a beast unto itself) attached. So I’d guess it’s in the 500-600 lb range.
I have 12 ft lifting straps rated for 2600 lb in a cradle configuration. I had the hoist in the 1/2 ton configuration.
I have moved it several times the same way.
Likewise I used the hoist to move my 1800 lb surface grinder. Albeit in the 1.5 ton position.
Thanks David your comments offers me some info to think about. PA has 4 foot with end loops although their 8 foot are endless whatever that means ? I assume your slings are 1 inch wide ? From whom did you purchase your slings ?
https://www.princessauto.com/en/1-in-x-4-ft-lifting-sling-with-end-loops/product/PA0008480170
https://www.princessauto.com/en/1-in-x-8-ft-endless-lifting-sling/product/PA0008021561
https://www.princessauto.com/en/2-in-x-8-ft-endless-lifting-sling/product/PA0008480162
I purchased them from Western Supply , a local equipment supply house. They are indeed an inch wide with reinforcement around the loops.
They may rated higher than I originally said. I can check tomorrow.
I'm looking at buying the same hoist, have you had any issues/limitations with it?
No issues whatsoever other than having to fill and bleed the cylinder when I first got it. To be fair, the instructions said it would be necessary. I had oil so it was no big deal.
@Dusty
I looked at my straps and they have a much greater capacity than I previously said.
Straight pull - 3100 lbs
Loop - 2400 lbs
Cradle - 6200 lbs
And they are 10 ft.
Blame it on my lousy memory.
Spent the day running conduit and electrical to supply power to the newly relocated mill and lathe. Two 4-gang 120v receptacles and one 240v for the mill.
Now I can put everything back in place...
@Dusty
Loop - 2400 lbs
Cradle - 6200 lbs
And they are 10 ft.
Thanks David good info to know before making a purchase., shall watch the sales as they turn up.
Chaos never lasts you'll have things in top shape soon enough just keep on trucking. Like your equipment covers, airborne dust and such is a sure killer on oiled machines and components. Hard to avoid when doing woodwork and shop rebuild.
Thanks @Dusty, indeed the descent into chaos was swift and so shall be the return to normal :)
