At least you figured out what happened. Pull the electronics apart and see what smoked. Might be a simple FET that is toasted.The problem is of my own making.
I needed to verify the connections at the spindle so I pulled the connector apart. Noticed that one wire had come unsoldered. So I resoldered it. Problem was that there was a solder bridge between that pin and the one next to it.
So when I started the spindle it was a dead short between two legs.
Live and learn I suppose.
$200 lesson.
Yeah I’ll pull it apart and see what I can make out.At least you figured out what happened. Pull the electronics apart and see what smoked. Might be a simple FET that is toasted.
