That's an option too. Thanks!If I remember right Keith Rucker just pulled one out switching to a vfd you might try contacting him about his.
@Darren - that’s was talking about with Megger test - cool they did one![]()
200' of vertical, slimy 1" abs, full of water, instantly freezing on the way out of the hole, with a 30?ish pound pump on the end definitly has some gravity to it. I actually have to do it again this summer, to add to the casing. It's too low for the grade. I'm going to replace the pump when i do.Marettes!!! OMG! That is crazy insane!!!
Our well is 217’ and the pump sits at about 180 ish. It is a pain in the arch to haul out - spans a good deal of the back yard / slimy and slippery 1” ABS all the way down to a heavy freaking pump and that PITA torquer. I have my trusty 1” pipe puller made up just in case. We have the well head with the side spigot for outdoor watering. Lots of fun!
That is a great idea of using it for testing the well pump. I have been contemplating pulling ours replacing it as I have no idea how old it is .For all you electrical guys basically megger testing wires or motor windings:
You hit the wire with a voltage well above it’s used specification -
So on the ship we would megger a 600 volt line/motor at 1000 to 1500 volts. The insulation will saturate with that increased voltage (like a capacitor type event) and you can read on the meter what the insulation rating is for what you tested. Typically anything below .5 Mega ohms is cause for immediate repair. We strive for over 500 plus mega ohms.
The old meters were dyno’s and you cranked them. Lot of guys got zapped for fun. The bad thing was if you left anything on the circuit you were testing you could blow it up - like TV’s and computers. Shooting 1000 volts into a new TV sucks.
For our large generators etc. we test them and if they are low we will have them cleaned and baked to remove moisture. Depending on the motor they can further dip it/increase the varnish to try and save it - as in Darren’s case.
The reason I asked if it was a 220/440 motor is sometimes the 440 windings are not great but the 220 combination can still work fine.
There are some cool things you can do with a megger tester. It is an annual event on the ship. I have one at home somewhere- was great for checking the condition of my well pump with out having to pull out 180 feet of pipe -
Except the test proved I had too -
Dang test!!! LOL.
Thanks for your insights Brent, I’m developing rules of thumb for when we should replace (600/347V operating) cables with low megger results.….Typically anything below .5 Mega ohms is cause for immediate repair. We strive for over 500 plus mega ohms.
Thanyou again Brent, that’s very helpful.…the marine electrical standards are under transport Canada TP127 and an excerpt:
…On board a ship, in a damp or wet environment we seldom see lower than 50 meg - usually it is off scale or “infinite”.
Way cool man! Good luck!Talked to Gary from Kilred Winding today.....they were successful in the repair of the stator and it passed the tests. I'll be picking it up tomorrow and hopefully reassembling the motor/generator this weekend, maybe even testing it. Super pumped!
Boy, that turned around pretty amazing!
You Dancin? If so, post a video so we can all laugh at you..... Er, I mean dance with you!
