Cross slide DRO
Just for inspiration I’ll point you to where I showed the embedded cross slide scale on my Myford. Link to post #16
@David:
@Xyphota's original post is here:
@Tecnico already linked to his install above.
These two guys were my inspiration.
I have not even installed my own yet. If you knock this one off, you are going to embarrass me AGAIN!
I don't think it's been mentioned yet, (perhaps it's a given) but there are three reasons for putting the scale inside.
1. Putting it on the front gets it in the way of swinging parts. Waaaay too easily damaged.
2. Putting it on the back robs tailstock travel.
3. Putting it on back means you can't bump your tailstock anymore. Bumping the tailstock is a great indexing method. Losing that feature would be a total bummer for me.
I don't have a Myford. By my reckoning, I will only require the length of the read head for the scale extension. The strip does not need to longer than the head itself. In fact, if the sensor could be put inside, the extension would not be needed at all. I think your lathe is similar in that respect.
Another thing to be aware of is the impact of a taper attachment. My taper has a fairly large shoe that attaches to the back of the cross-slide. So I plan to make this shoe my extension. It does mean that the taper shoe becomes permanent. But I don't think that is a big deal. I'll machine the tape groove in both to make sure things line up. I may also use alignment pins.
If you are planning a taper attachment, you might want to put the cross-slide scale on the backburner until you can do both projects.
Of course the real purpose for this whole post is to try and restructure and normalize your efficiency processes. The amount you get done is criminal. Since I'm too far away to sneak in and sabotage your shop like @140mower and @jcdammeyer want to do (and I fully support), about all I can do is try to add more complexity to your thinking and work processes. I wouldn't fight it if I were you. You will be much happier once you understand that happiness is inversely proportional to the rate of project completion......
In that case I only need about an inch plus the depth of the read head which is 35mm so call it 26mm + 35mm = 61mm
Now you & @Susquatch are getting close to what I did on my Mini-Lathe (only the scale is mounted to an extension of the CS), Iand I eliminated the backsplash. The read heads for X & Z are mounted on a bracket attached to the saddle:
Details are in HSM Jan-Feb 2024 (pay no attention to the title of the article - it got missed in reviewing the pre-press:
I have no idea what "bumping the tailstock" means. Can you elaborate?
Sure. I use contact with the cross slide as a register. It is called "bumping". It's sort of like a vise stop.
Say for example I'm deep drilling. I "bump" the tailstock against my cross-slide and drill till I feel the need to clean or apply more cutting oil. I back off a quarter turn on the tailstock quill, then loosen the tailstock, pull it back, and clean chips. Then I apply more oil, slide the tailstock back to bump the cross slide again. Now I know exactly how deep I am. A quarter turn will get me drilling again. That way I don't need to faff around wondering where contact is and worried about contacting bottom too fast or too slow.
This is also particularly useful when you need to drill exactly 2" deep. By using the bump sequence, I can read my depth right off the quill. That's because my quill is indexed to the back of my cross-slide. Easy peasy.
