Create a tool bar box using EDM wire cutting
a smile
Lifelong hobby - cold iron
Blank size: 125*70*50
Cutting T slot +V slot, an area of about 14000m square meters, takes 4 hours.
2023_08_01_19_27_IMG_1156.JPG 2023_08_02_14_39_IMG_1174.JPG 2023_08_02_14_40_IMG_1180.JPG 2023_08_02_14_41_IMG_1187.JPG
Milling machine drilling
Rectangular slot cutting, area: 10000m square meters, estimated about 3.5 hours (can be completed in about an hour)
It is basically consistent with the estimated time, and the cutting effect is OK, which can confirm that the control logic circuit of the EDM machine tool is correct. Simple cleaning.
Round hole chamfer.
Finish thread
assemble Installation test
Paint the base contact surface Fit test
The outside fit is very good, and the middle two surfaces have less contact area - it will be corrected in the grinding machine processing after heat treatment
a smile
The normal working of the EDM cut significantly improved my production confidence and also allowed me to improve efficiency. Then I made more EDM drawings.
I must learn more CNC programming, which will also enhance my machining ability. Today, I try programming to peck holes and try machining. Proves that it is perfectly possible to learn examples from the manual, but lacks the skills to learn from the veteran technician!
2023_08_04_17_20_IMG_1336.JPG 2023_08_04_17_47_IMG_1340.JPG 2023_08_04_17_55_IMG_1346.JPG
a smile
After experiencing painful wire breaks, wire breaks, wire breaks, I checked my PLC control programming, finally found the root of the problem, readjusted and tried again, and completed a perfect cycle.
2023_08_05_14_56_IMG_1388.JPG 2023_08_05_18_01_IMG_1394.JPG 2345截图20230805185045.png
The PLC program should still have several small deficiencies that need to be patched in free time
Dan Dubeau
You're a talented guy, with a nicely equipped shop. Thanks for sharing your projects.
We send a lot of work out for WEDM at my day job, but it's something I always wanted to learn and bring in house. Went just don't do enough of it to make it pencil out and get our own machine.
a smile
Thanks for the compliment, I guess I just enjoy trying different mechanical devices and getting it to work. After getting the EDM wire cutting many of my ideas can be more easily realized, I can freely change the drawing, the current view - the effect is still good, I used the abandoned iron core, made some boring jig. However, due to lack of experience, there were some deviations in the inner diameter, but this still allowed me to get 5 usable boring tool jig.
2023_08_09_20_02_IMG_1603.JPG 2023_08_10_10_54_IMG_1618.JPG 2023_08_09_07_03_IMG_1573.JPG 2023_08_10_14_43_IMG_1622.JPG 2023_08_09_07_01_IMG_1569.JPG
If you need some EDM for personal use, I can help for free. But be aware that shipping is a big expense!
Moreover, the friends of this forum will receive free help from me (within my processing capacity)!
Because this is my hobby, I don't make a career out of it!
