Blank size: 125*70*50
Cutting T slot +V slot, an area of about 14000m square meters, takes 4 hours.
Milling machine drilling
Rectangular slot cutting, area: 10000m square meters, estimated about 3.5 hours (can be completed in about an hour)
It is basically consistent with the estimated time, and the cutting effect is OK, which can confirm that the control logic circuit of the EDM machine tool is correct. Simple cleaning.
Round hole chamfer.
Finish thread
assemble Installation test
Paint the base contact surface Fit test
The outside fit is very good, and the middle two surfaces have less contact area - it will be corrected in the grinding machine processing after heat treatment
Round hole chamfer.
Finish thread
